Clutch Issue???
Old Feb 17, 2009 | 06:04 PM
14racing's Avatar
Clutch Issue???
Lately i have noticed that sometimes when i let out my clutch i hear somewhat of a banging noise. It doesn't seem to do it all the time but its beginning to bother me. I jacked it up and had my dad run the truck letting out the clutch and then changing directions. Then you could really hear it. I then put it in gear and crawled under neath and wiggled the drive shaft. I could hear a lot of spring noise up in the clutch area. Do the damper springs in clutch disks cause some issues on these trucks?
Old Feb 17, 2009 | 06:22 PM
PapeCAT's Avatar
Could be broken fingers in the pressure plate, and/or/caused by a bad/overheated throwout bearing.
Old Feb 17, 2009 | 10:21 PM
Alwaysworking's Avatar
alwaysonDTR
what clutch do you have?
mine rattles alot because of the heavy duty hub center hub
Old Feb 17, 2009 | 11:57 PM
Richie O's Avatar
366 Spring Chicken
I have broken the torque springs out of a gasser rig before. Usually it makes it buck back and forth when you try to ease on or off the throttle. Kinda makes your head whip back and forth. Mine was an easy thing to check because it blew a hole through the bell housing.
Old Feb 18, 2009 | 05:34 PM
14racing's Avatar
Looking through the clutch fork hole it looks like it has a Sachs clutch it in. When you try to inch the clutch it gets kind of jerky if you take off in low or if you are trying inch it out in reverse. You can only hear the banging noise when you take off and it seems worse than it used too.
dan123dbl
Feb 13, 2015 05:47 PM
ChrisM55
Jun 24, 2006 09:12 PM
Bill Tomlinson
Apr 23, 2006 03:09 PM
DDysput
May 5, 2004 07:44 AM
