cleaning melted piston from turbo
hey guys i was wondering if there was such a solution to cleaning the melted piston material out of my turbine housing. when my piston melted it push molten piston material all through my exhaust manifold and thinnly coated the in side of the turbine housing
, it suprisingly did not ruin the turbine blades
and the turbine blades still spin freely without any catching, but the turbine was a brand new 12cm non wastegated turbine housing and i want to keep if possible. so does anyone know of a chemical than cleans whatever the piston is made, off cast iron???
and the turbine blades still spin freely without any catching, but the turbine was a brand new 12cm non wastegated turbine housing and i want to keep if possible. so does anyone know of a chemical than cleans whatever the piston is made, off cast iron???Sheff
Many, many years ago in a past life, I used to work for Holset. We used to clean the returned turbine wheels and housings with a caustic solution. The turbine wheel is made of Inconel and the turbine housing is made of ductile iron which are not easily attacked by the caustic, but it dissolves the aluminum. Don't let it contact the low alloy steel shaft.
whats the name of the caustic solution, or is "caustic" the name
Stove-top home-made gun-bluing solution, the recipe that used to be in the old Dixie Gun Works catalogs, will dissolve aluminum on contact,
volcanically.Don't ask me how I know this.
I do remember that Sodium-Nitrate fertilizer and Red-Devil lye were two of the key ingredients.
mppd20
Nov 6, 2009 09:53 AM
UnrulyNFS
21
Mar 23, 2008 10:30 PM
Bobcat698
91
Nov 3, 2007 03:19 AM
powerstrokin03
Mar 8, 2007 03:15 PM
