Check engine light on
Old Mar 14, 2004 | 11:27 PM
cLAYH's Avatar
Anyone know what triggers the check engine light? It came on today while I was pulling a hill at WOT.
It goes away after shutting the engine off but then comes back on after driving for a short while. Thanx.
Old Apr 15, 2005 | 09:49 AM
jiMMyCTD's Avatar
Mine just poped on today as well cruising down the highway to work. going to check some wires at lunch and drive her home with fingers crossed. jiMMy
Old Apr 15, 2005 | 10:52 AM
DJ's Avatar
DJ
changed your fuel filter lately?
Old Apr 15, 2005 | 11:24 AM
jiMMyCTD's Avatar
about 600 miles ago
Old Apr 15, 2005 | 12:52 PM
DBF's Avatar
DBF
Re: Check engine light on
According to the book, the Engine Controller turns on the Check Engine lamp when the input from one of these sensors fails:
Manifold Absolute Pressure (MAP) sensor
Throttle Position Sensor (TPS)
Coolant Temperature Sensor
Battery Voltage Sense
Battery Voltage too high
Are any Fault Codes showing up when you do the key on-off-on-off-on thing?
DBF
Old Apr 15, 2005 | 12:54 PM
jiMMyCTD's Avatar
im guessing mne has to do with over charging then, sometimes my battery will shift in the tray and hit the lip of the fender. i noticed when the light was it was charging higher than normal.
thanks for that list.
jiMMy
buddy26
Feb 15, 2008 12:17 PM
choppers555
Oct 16, 2007 12:29 PM
alltimelow1
Apr 6, 2005 07:28 PM
Fillerupsonny
Oct 9, 2002 06:01 PM
