Can I change elec. speedo for mech. speedo?
Old Mar 8, 2011 | 04:09 PM
TJE's Avatar
TJE
I've got a 91.5 truck...has the electronic speedometer. Can I change this out for a mechanical one....if I can find one? The speedo, odometer, and trip meter all quit, however the cruise and the o.d. all work fine. I looked in the sticky and did what was suggested there but to no avail. Must be electrical problem.
Thanks
Old Mar 8, 2011 | 06:00 PM
Richie O's Avatar
366 Spring Chicken
Overdrive will not work if you do away with the electronic speedo. ( unless you handle overdrive by a toggle switch, or aftermarket pressure switches on the tranny.)
Old Mar 8, 2011 | 07:16 PM
TJE's Avatar
TJE
I figured something wouldn't work. Speedo shop guy says he can fix mine for 200.00! I thought I might find a cheaper solution.
Thanks
Old Mar 8, 2011 | 08:35 PM
Richie O's Avatar
366 Spring Chicken
Find a used speedo head if thats the problem. Its either a wire problem or a speedo head issue. If the Vehicle Speed Sensor ( VSS ) was bad, then overdrive would not work. Your PCM needs a speed signal to select overdrive. Or so thats how I understand things.
Old Mar 8, 2011 | 08:56 PM
TJE's Avatar
TJE
Yeah "wanna" told me once before it was a head issue. The VSS is new. I did try all of the salvages around here but nobody had one. I might try flea bay, or the classifieds.
Thanks
Old Mar 8, 2011 | 09:17 PM
TJE's Avatar
TJE
scratching my head now. If od is working, and cruise is working.....I'm wondering why won't a mechanical speedo work? I've probably been up to long
Old Mar 8, 2011 | 09:47 PM
Richie O's Avatar
366 Spring Chicken
Because a mechanical speedo can not " tell " the pcm what is going on. The speedo signal travels through the pcm and then goes to the head unit. The only year with the mechanical speedo and the cummins was 89 which had no pcm, or overdrive. The vss signal talks with the throttle sensor and as a pair they decide the overdrive shift via the pcm.
Old Mar 8, 2011 | 10:04 PM
TJE's Avatar
TJE
Gotcha....So I wonder what years would work? Any ideas?
Thanks
Old Mar 8, 2011 | 10:06 PM
TJE's Avatar
TJE
Gotcha....So I wonder what years would work? 90 thru 93?
Thanks
Old Mar 8, 2011 | 10:13 PM
I'm sure glad my crew's donor was a 89.....
Good luck.
Old Mar 9, 2011 | 08:53 AM
Trebor's Avatar
Aren't there some older 2 piece speedometer cables that drove the older 80's cars & trucks cruise control units? I know GM used them. If so, then why not mount the VSS under the hood and feed the upper cable from it to the speedometer head? It might require an adapter of female to female threads if available. I cant remember how the intermediate cruise control was connected but I think it had 2 female connections.
Old Mar 9, 2011 | 02:20 PM
TJE's Avatar
TJE
Thanks for the idea....however you might as well be speaking a foreign language. I think I've located one from a member here on the forum. I found a salvage and I can have mine rebuilt for a tad more than what they wanted!
Regards
Old Mar 9, 2011 | 06:24 PM
dart3404's Avatar
there were some years of dodge products that had a speed sensor with a cable hook up on them i think some of the early front wheel drive stuff maybe i will check into it and get back
Old Mar 9, 2011 | 06:43 PM
Mark Nixon's Avatar
SOME of the '86-'89 Dodge trucks have a speed sensor (VSS) wired in at the speedo head unit.
It is a 2 wire unit, and I believe, in the 1989 diesel trucks, it shuts the grid heaters off above a certain MPH.
I have an old '89 out here I fully intend to dissect the speedo and wiring from for this very reason, to find out the routing of the VSS on the speedo.
Mark.
Old Mar 9, 2011 | 06:48 PM
Mark Nixon's Avatar
Dodge Dakotas prior to 1995(?) have this set-up, but they also had a @ 1/2" screw on connector for the speedo cable.
Dodge Fullsized pick-ups used a @ 7/8" one.
Not to worry though, certain late '80s Jeeps used an adaptor sleeve on THEIR VSS' that will work on the Dakota sensor to adapt it up to the fullsize cable end.
Mark.
Totallyrad
Jul 19, 2011 07:41 AM
jon05ctd
Aug 27, 2006 04:14 PM
omaharam
Jun 1, 2006 05:33 PM
hotdram
30
Jun 26, 2003 04:35 PM
Demon_Customs
13
Dec 19, 2002 07:14 PM
