brake drums
brake drums
I'm trying to up grade my brakes and had trouble geting new drums. I did a search on this site and found that the drums on my w250 are the same as d350 dually and so are the wheel bearings and seals, So can some one tell me what is missing to put duals on my truck? is it all in the hubs? I have dually adaptors on it now but would like to put those on the front and have the same wheels all the way around. Ken
I'm pretty sure the axle housing is completely different, with different spindles. I know that the hub seals are different: CR seal 28746 for SRW and 30033 for DRW. I recall the 30033 seal for the duallies is quite a bit larger.
Not sure on 2wd's, but on 4wd, the inner bearing and seal is considerably larger on the 350. That said, the hubs are different and the spindles are larger too. Also the 250's use a 32 spline axle, and the 350's use a 35. I guess what I am saying is, unless you swap to a dually axle you won't have the same strength.
The front spindles are the same DRW or SRW. If you can find a set of dually hubs, you will be all set. You can use either the late model (post 91) Dodge hubs, or mid eighties chevy hubs. The earlier Dodge hubs will fit, but the brakes & lockouts are different, generally considered not as good, and you would have to swap them as well.
The dually rear hubs & spindles are different, and the axle housing is wider on the duallies. I also thought that the stud size was differnet on the duallies, and thus the drums were not interchangeable on the rear either
but the knurled portion that holds the hub and drum together may be the same
BTW, Dan: Everyone gets abducted, its just that the mind control doesn't work as well on rednecks and wackos . . .
While we're on the topic, I believe there is a difference in axle housings between a dually pickup and a dually cab & chassis. I think the frame rails are farther apart on the c & c, for what it's worth.
Pete Miller
15
Dec 17, 2005 01:16 AM
