Boost and Pyro gauges
Old Aug 16, 2003 | 12:04 PM
The Old Man's Avatar
Okay, so I don't know what I'm doing. Hate to admit it but it's the truth.
Got a couple of questions that I haven't found the answers for.
1 - Where is the plug for plumbing the boost gauge on a '93. ??? The only instructions I've seen so far are for 94's and up. : I read somwhere I could drill and tap the intake horn.
2 - I had a PacBrake installed a few years ago and it has a plug right after the turbo and ahead of the valve. Would it be okay to put the pryo probe there. At least there wouldn't be any drilling for me to screw up. :-
Old Aug 16, 2003 | 01:56 PM
Monty's Avatar
Re:Boost and Pyro gauges
If you look right below the intake horn, you will see a 1/8" plug on the side of the head. This is where you need to tap into to get your boost readings. Tapping the intake can be done but isnt needed on your 93.
BTW: you can use the TST instructions for the boost gauge install. The 1/8" plug will be almost in the same place as the 12v 2nd gens.
Alot of guys run there thermocouple post turbo. I ran mine 2" back from the turbo on the downpipe up until 2 years ago. I then moved it to pre turbo to get a more accurate reading as the temps can vary from pre to post up to 500*.
Old Aug 16, 2003 | 02:22 PM
Thanks for the info, Monty. I guess I'll go ahead and do the drilling for the pre turbo reading. I seem to always want to take the easy way out.
You know, I tried that 1/8" plug last nite and I didn't think it worked. (1:00 in the morning is not a good time to tinker). Anyway, just tried again. Yep it does work.
Appreciate your help ;D
Old Aug 17, 2003 | 02:43 PM
Bushy's Avatar
Patron Saint of 1st gens
For those who have problems getting to the plug or whatever.... you can interrupt the boost signal line that goes from the manifold to the AFC housing too...
Just put in a "T" fitting and take your signal from there.
Bob.
jimlj
Oct 20, 2014 05:08 PM
Chopper_Bob
13
Jan 10, 2007 09:54 AM
dncoy
Aug 30, 2004 08:46 PM
wannadiesel
Apr 19, 2003 10:50 PM
