Bolt in Hydro Boost conversion!!!
Old Feb 11, 2012 | 03:31 PM
fitter48093's Avatar
Let me start by saying this mod is not a cheap upgrade. Others have done this considerably cheaper with used units and wrecking yard parts. However I put a considerable amount of research into this and from that went this route.
I started by contacting Talon Hydraulics, I spoke with the owner Butch and discussed my needs. He advised me that a truck with ABS even rear wheel needs a special hydro unit. I agreed to send him my vacuum booster to take dimensions from and create a mount and a pedal push rod. After a few days he sent me this
Pictured above is one of their high output new units. He also has reman units ready to go . price differance is around $50.00
Here is a close up of the firewall mount and push rod
I sourced lines and the master cylinder from a local auto supply, they are for a 1996 Chevy K3500 truck with the JB8 heavy break option.
I also wanted to put a cooler in the system while doing this so; From Auto Zone I picked up this small power steering cooler.
You will also need this Vacuum tee to complete the install and reconnect the vac. lines connected to the removed check valve on the booster.
Here I have mounted the unit to the fire wall with the hardware supplied with the booster.
I also mounted the Master cylinder and fitted the break lines; the front line needs to be remade with a new master side nut.
I also installed a new power-steering pump from a 1999 RAM 2500 with dual returns to accommodate the steering gear and the hydro boost.
Mounted the new cooler onto the A/C condenser and ran the hoses.
Old Feb 11, 2012 | 03:32 PM
I fit up the other pressure and return lines with slight bending for clearance and proper fit to the truck
Add all the fluids and bled both systems; Power steering took 1 1/2 gallons of fluid. I added about two quarts of break fluid to the system after full bleed down.
This system will throw you thru the windshield if you are used to the stopping of the OEM system. This has been by far the best upgrade I have done. I have roughly $550.00 in the complete system + fluids. Let me know what you all think.
Old Feb 11, 2012 | 03:54 PM
Gots_a_sol's Avatar
Looks good. I'm one of those cheap asses that used junkyard parts and it still provides the 'throw-you-through-the-windshield' braking action compared to stock.
I used the same hard lines and pump as well, which I did buy those new (eventually) as my stock p/s pump started leaking (had T'd the return lines together at first) and one of the lines had a pin hole in it.
Old Feb 11, 2012 | 04:04 PM
Well, I like the way you did the work, and it looks really neat and professional.
Not real sure how a plastic tee will hold up, but I'm sure you'll let us know if you had to switch it over to brass.
I don't know if I like the idea of being thrown up against the windshield in my truck. I think I'll start using my seat belt.... thanks for the reminder
I think you'll miss that lapse in braking and the "swoooooosh" that you used to have when you applied your brakes with the stock booster setup. No more "Swooooosh" .... I just don't know....
Old Feb 11, 2012 | 04:23 PM
simplysmn's Avatar
The Plastic T is for the vac lines
Old Feb 11, 2012 | 04:36 PM
DOH !
I missed that.... as if you couldn't tell.
Old Feb 11, 2012 | 04:37 PM
bobva's Avatar
93 dodge takes 2.7 pts power steering fluid your telling me there's 144 ounces in the in the hydo & cooling system. WoW
Now my ?s
Why didnt you go with a remote reservoir style power steering pump?
Why no filter?
What with the vacuum plastic hose fitting?
Other than my Qs looks great.
Old Feb 11, 2012 | 05:49 PM
For the fluid you are correct. I bought a gallon the first trip to the store, used about a quart to flush the old system and needed to return for a second gallon. After test drive and topping off about 1 quart left.
No filter because everthing is new, and I was concerned with pressure drop after the cooler.
The plastic tee is needed to tie all the vacuum system together. I removed the check valve when the vac booster was removed so I used the tee in it's place.
Old Feb 11, 2012 | 06:00 PM
300stw's Avatar
i want to do the same thing,, i am tired of double pumping the brakes,,,,,
contact # for booster and maybe a list of part #,s
thanks
Old Feb 11, 2012 | 06:17 PM
bobva's Avatar
I guess I better get some more
I'll be putting one on there cheap.. BTW your steering gear is old
Thank you I guess I was really S O S oh well.
Been looking into this upgrade also.
I'll going with a remote tank easier to check & fill.
I was also thinking more fluid but now
If I didnt say it before looks great.
Old Feb 11, 2012 | 06:25 PM
If I didn't say it before looks great.
You might be right on the filter, Maybe I should of considered it. I couldn't find a good remote tank setup. I think you would need one from a newer third gen truck than have to change out the pulley to the vac. pump drive and figure out a mount.
Old Feb 11, 2012 | 07:02 PM
bobva's Avatar
Heres my plan
Take 93 cummins pump and a 85 w350 style pump
http://ramchargercentral.com/technic...-hydro-assist/
remove and swap pump tanks
http://www.corvette-restoration.com/...mp_rebuild.htm
You can use the control valve system out of the 93 cummins or the 85 w350 they are both metric just dont mix up the parts.
The upper tank can be any homebrew look you want.
Old Feb 11, 2012 | 07:11 PM
Heres my plan
I don't think you would have to swap tanks. Use the '85 pump with the drive adapter from the '93 pump.
Old Feb 11, 2012 | 07:20 PM
jstone44720's Avatar
Has your power steering changed since installing this setup?
Old Feb 11, 2012 | 07:25 PM
bobva's Avatar
Remote tank
http://www.speedwaymotors.com/Speedw...anks,2062.html
Thats just a one of a million.
