Belt Idler question
Old Sep 24, 2007 | 11:52 PM
gcliburn's Avatar
Belt Idler question
Can a pulley/bearing be bought seperate from a belt idler/tensioner assembly. I replaced the tensioner a year or so ago, but the bearing in the pulley is starting to squeal and I hate squeals. I am hoping I won't have to buy the whole assembly. Thanks for the help.
Old Sep 25, 2007 | 07:41 AM
dizzel's Avatar
Yes!
You can buy just the pully wheel with the new bearings installed. The bearings won't come out though, I tried this and realised after breaking the wheel that the bearings are formed into the plastic.
I ended up getting a new pully as the cost was only about 60 to the pully being about 35. I have some good synthetic grease and I carefully pried out the seals and stuffed the one side with grease. As there are two bearings in each wheel you can only pack one side of each bearing.
When prying a seal out I always pry the outer sealing surface with a box cutting knife right where the metal ring sits, trying not to pearce the seal.
Hope that helps
Diz
Old Sep 25, 2007 | 11:00 AM
rlyons's Avatar
That pully is at AutoZone for less than $20.00.
bobsallyh
Nov 6, 2014 07:33 PM
DodgeDiesel61
0
Jul 28, 2010 11:14 AM
thames1948
Sep 26, 2007 04:59 PM
apwatson50
Mar 3, 2006 06:26 PM
redhornet
May 24, 2005 11:07 PM
