Axle repair
Old May 14, 2007 | 11:50 AM
Falcon1's Avatar
Question Axle repair
I was looking at my front axle (Dana 60) yesterday while givin her some grease and I saw that the u-joints to the axle shafts were in need of some replacement. How difficult is it to take them out to replace? I have never done this but it needs to be done soon.
Greg
Old May 14, 2007 | 06:00 PM
bullfrog5.9's Avatar
i did mine it was not to bad wheels come off brake clapper and the hole hub and bearings come out then when u get to the cone take all 8 bolt i think that hold it on but mark a line on the cone to the of peace that it is bolted to i forget whats its called. so when u put it back on it goes on the same way the clapper bracket comes of with the cone once the bolts r off and axle will slide out . cone will be stuck in there from rust and stuff so hit the cone up and down but not where the bearings sit . here in canada the joints r 95 dollers each i dont know y they r so much but what ever .
Old May 14, 2007 | 06:39 PM
phantom_ram's Avatar
I just had mine apart, I used the sticky to get mine apart https://www.dieseltruckresource.com/...d.php?t=143024
That was the first time into a D 60. Careful with the hub there was a lot of little parts. And the caliper was different from anything I've been in, you'll need an allen wrench for the bolt and a hammer and a pair of pliers for the "slide lock thing". But mostly just bolts.........
Good luck
Old May 15, 2007 | 01:08 AM
Murf's Avatar
It is a job getting to them and getting them out. But it can be done with basic handtools. And it's one of them things that once you do one side of the truck, you're a qualified expert! So the opposite side will be easier and go faster.
Once you do get the axleshafts out REMEMBER!!! Even tho it doesn't look like it, there ARE retainer clips on the U-joint caps. Dana pulled a fast one on us and put them on the INSIDE of the yoke. So, If your axle shafts were like mine you'll have to lubricate, pry, poke and prod just to find 'em. After that it's reasonably straight forward.
Good luck man! Let us know if you got any more questions.
Old May 15, 2007 | 10:07 AM
Falcon1's Avatar
Thanks all for the input. I will be doing the task soon, no big hurry now that 4wheel drive is not needed as much as the winter.
Greg
NHDiesel
15
Aug 24, 2016 11:05 PM
Jim Lane
May 2, 2011 05:13 AM
high bid
Apr 17, 2008 06:09 PM
Ram of Steel
May 15, 2007 09:35 AM
Paul Winey
Jun 22, 2004 08:09 AM
