Auto trans. question
Old Jun 18, 2011 | 06:05 PM
bill-d-c's Avatar
Will a bad throttle positioning sensor cause a 92 auto trans to shift in and out of overdrive? If anybody knows, I sure would appreciate some good advice. It's about a 350.00 part, don't want to buy one if I don't need it.
Thanks
Old Jun 18, 2011 | 06:50 PM
1stgenCTD92's Avatar
yes. if the TPS is out of adjustment or failing than it will do that. Have you checked the fluid? sometime when mine is a little low it acts a little funny.
Old Jun 18, 2011 | 08:12 PM
Onemoparnut's Avatar
A bad tps will cause that problem for sure. Look in the sticky at the potentiometer install much cheaper than a tps and it works well.
Old Jun 18, 2011 | 08:58 PM
bill-d-c's Avatar
Thanks guys.
I did check the fluid, it was OK. Also added
Sea Foam Trans Tune which didn,t help (do additives ever help?) I was told that the TPS might be the problem, but not being an Auto trans guy he wasn't sure.
Bill
Old Jun 18, 2011 | 09:44 PM
There is a test procedure in the sticky to test the tps.
DodgeDiesel61
Jun 3, 2008 07:50 PM
jca001
Mar 8, 2005 04:42 PM
KSmith
Jun 10, 2004 07:23 AM
KC
Nov 22, 2002 09:12 PM
KC
Nov 18, 2002 02:05 PM
