Anyone have a getrag 360 manual?
Old Dec 20, 2007 | 09:55 AM
Kim8839's Avatar
Thanks everyone, a couple of guys sent it to me. I try and do the rebuild after the holidays. I hope it won't take me too long to get it done.
Thanks
Kim
Old Dec 20, 2007 | 06:26 PM
dumptruck200's Avatar
Its a good idea to check the shifter forks over carefully hwile you have the top off.
Edwin did a good writeup on getrag shifter problems. The title is Getrag Shifter - How It Works.
dumptruck200
Old Jan 11, 2008 | 07:06 PM
EClancy's Avatar
who has the manual....it appears spunbearing has not been online in a while. if someone has a copy and can email it, let me know please.
Old Jan 11, 2008 | 08:36 PM
Kim8839's Avatar
I have it, whats your email address.
Old Jan 12, 2008 | 07:56 PM
EClancy's Avatar
kim....PM sent...thanks
Old Jan 13, 2008 | 10:19 PM
Did everyone get a copy that needs one?
PM me with your email and address and I'll send it to you.
Old Jan 14, 2008 | 10:04 AM
Kim8839's Avatar
Yep, thanks for the efficient follow up, I sent it to Eclancy the other day.
Old Jan 14, 2008 | 06:14 PM
EClancy's Avatar
i got it...thanks
Old Jan 22, 2008 | 06:55 PM
too tall's Avatar
Anyone still have the file?
Old Jan 22, 2008 | 08:03 PM
Sure, too tall. PM me with your email and I'll send it to you.
Old Feb 17, 2008 | 04:54 PM
mtipcc's Avatar
manual for a 91 dodge getrag 360 manual
Hi everyone,
I'm new to the group and need a getrag manual for my 91 cummins. it gets locked up in od and won't go into reverse
Thanks
Clark Howard
mtipcc@hotmail.com
Old Feb 17, 2008 | 04:58 PM
mtipcc's Avatar
Evening dump truck
I new to the group, and would sure appreciate a manual for my 91 d250
Clark
mtipcc@hotmail.com
518 429 5591
Old Feb 17, 2008 | 05:07 PM
mtipcc's Avatar
Sorry dump truck
I ment to say a tranny manual for my 91 d250 getrag 360
Clark
mtipcc@hotmail.com
518 429 5591
Old Mar 10, 2008 | 08:32 PM
avewilson's Avatar
I would love to have this manual as well. Does anyone have any experience with "rebuild kits" like this one -
http://cgi.ebay.com/ebaymotors/ws/eB...TQ:MOTORS:1123
Also they have a kit without the synchros for about $110 less.
My trans shifts fine, but i can tell that the bearings are going out .. (infamous low speed 4th gear grinding) Also, acceleration isn't as smooth anymore, like the trans main shaft is vibrating as more power is applied. Leads me to think its a bearing issue.
Also - changed the oil last week and there were a good amount of silvery metal shavings in it. No brass as far as i could tell, so I'm guessing the synchronizers are still good.
Should I try to save the $110 and get the one with no synchros?
Also - (sorry for the long post) how difficult is it to put one of these things back together? Is a press needed? How tough is shimming the bearings to the right clearance?
Thanks a ton.
Avery
Old Mar 12, 2008 | 12:25 AM
fozzy's Avatar
Does anyone have the PDF file handy for the Getrag? Mine is a '92. I'm ok with the overhaul (retired trans guy) just would like info on the specs like bearing preload.
Ayery....to answer your question a press would be very helpfull to press the new bearings on. You could cool the shafts in the freezer and warm the bearings in hot oil then they should drop on. I have seen a properly sized pipe used to install bearings too. As for saving cash on the syncros, if it shifted fine then just inspect them real close when it's apart. The kits often have lesser quality rings than the original or OE ones.
Thanks
