Anyone have crossover steering with 0-2'' lift?
Old Sep 27, 2011 | 08:22 AM
  #136
Mieser's Avatar
The WJ pitman in my crossover conversion let the TRE sit at the same level as the end of the splined shaft that the pitman arm mounts to on the steering box.
( That has to be the worst explanation ever )
The leaf spring will hit the steering box shaft at the same time as the TRE ( at the pitman arm ) using the WJ pitman arm.
( That wasn't much better )
Old Sep 27, 2011 | 08:24 AM
  #137
BILTIT's Avatar
Completely understand what you are saying. That is exactly what is needed.
I hope mine shows up soon. I have a feeling i will need a different draglink too which will keep me down for another week
Old Sep 27, 2011 | 01:19 PM
  #138
1990's Avatar
I just ordered some DOM and the Poly Performance double adjuster. I will have my front axle rebuilt tonight or tomorrow. Then i will be placing it under the 2WD.
Then i will be starting on my crossover set-up with stock 93 front leaf springs.
Old Sep 27, 2011 | 02:41 PM
  #139
Mieser's Avatar
What thread count did you get on the poly performance adjuster?
What TREs are you planning on using for the drag link?
Old Sep 27, 2011 | 05:36 PM
  #140
BILTIT's Avatar
So i received the WJ pitman arm today, looks promising!
The price i quoted earlier ($46) INCLUDED a shipping charge of $15 so you that are south of the great white north should be able to get it for pretty cheap.
Old Sep 27, 2011 | 09:14 PM
  #141
BILTIT's Avatar
As you can see the WJ arm is by far the best fit (good job meiser on scoping it out for us). Partsmike removed the master splines and reamed it but i think they reamed it too big! My TRE goes in very far, but for the cost i can order another. I do see some issue with the draglink now though. I am going to weld up the box mounts and get everything solidified and then start mocking up what i need for a draglink.
Attached Thumbnails Anyone have crossover steering with 0-2'' lift?-img-20110927-00350.jpg   Anyone have crossover steering with 0-2'' lift?-img-20110927-00353.jpg   Anyone have crossover steering with 0-2'' lift?-img-20110927-00352.jpg
Old Sep 28, 2011 | 06:01 AM
  #142
1990's Avatar
7/8 - 18
I'm using Chevy drag link ends because that is what my steering arm needs. I'm going to try a drag link end on the pit man arm side don't know if it will work yet.
I think i'm going to order the WJ pit man arm actually. But if it's to big for a TRE the it will definitely be too big for a DRE.
Old Sep 28, 2011 | 09:05 AM
  #143
Mieser's Avatar
It does look like they reamed it a little large. They might have been thinking or test fitting another TRE. There are some small differences in taper sizes. I would call them and get some more info. I don't know what TRE NWF used?
That is a more than fair price for sure. I would have gone that way instead of modifying my own.
It was the best fitting arm that I could find by far.
How does your drag link look now? Did you check the center to center distance on your steering arm? If its longer than 6" you might have to trim the front of the crossmember.
I hope people see that there was a method to my madness on using the parts that I did!
Old Sep 28, 2011 | 12:13 PM
  #144
BILTIT's Avatar
NWFAB site shows that they use ES2234 ''1 ton'' TRE.
Old Sep 28, 2011 | 01:58 PM
  #145
Mieser's Avatar
Helpful TRE information....
http://www.partsmike.com/tech-help/tr-dl-id/
I think Parts Mike did a .791 x .772 taper when you needed a .773 x .664. That would explain why the TRE is sitting so deep.
Old Sep 28, 2011 | 04:45 PM
  #146
BILTIT's Avatar
Yup, they reamed it wrong. I am in the process of getting another from them with the correct taper, only take another week to get here...........but they are giving me a deal.
Atleast i can mock everything else up.
Old Sep 28, 2011 | 07:03 PM
  #147
1990's Avatar
I will take your wrong WJ pitman arm! Let me know a price.
It will work perfect for my drag link ends
I'm in Ontario so shipping won't be to bad.
Old Sep 28, 2011 | 09:12 PM
  #148
BILTIT's Avatar
pm sent!
Old Oct 9, 2011 | 05:42 PM
  #149
1990's Avatar
A crossover steering setup for a 2WD converted to 4WD.
The 2WD crossmember is 3-4 inches closer to the oil pan.
This photo is taken from the steering arm looking towards the stock 2WD pitman arm.
Old Oct 12, 2011 | 10:26 PM
  #150
BILTIT's Avatar
So alittle update. I finally received the proper pitman arm. I finished welding up the drivers side frame/box reinforcement plate.
Its my birthday tomorrow so i doubt i will get much done on the truck, lol.
This weekend i am hoping to have everything tied up and be able to test the draglink.
