another wont start thread
driving home truck sputters and dies, try to crank key nothing, lights work ignition buzzer works, i smelt an electrical burn briefly. one of my orange fuse links fried. i put the ends together to test, turn the key and it cooks again. the starter seems to work and i took the relay apart and it seems to work there is no voltage at the fuel pump maybe because when i turn the key the fuse burns
https://cimg2.ibsrv.net/gimg/www.die...2fac22af54.jpg this thing what ever it is is warm to hot to touch a day later. |
Looks like a turn signal flasher. Where was it?
Originally Posted by mknittle
(Post 3326033)
Check and see if you still have a dead short with it unhooked and the wires not touching. if the short is gone try the turn signals.
nope soon as i turn the key to run it smokes the fuselink, ok i found that it is the ignition lamp time delay does not seem to be my problem i hsve an ign switch coming from rock auto just in case
Ya that's the timer for the halo light around your ignition switch
