Aftermarket Lift Pumps
How many of you first gen guys are running an aftermarket lift pump like Fass or airdog? I'll be pulling my injection pump off to fix a few leaks that have showed up recently, and figured I might install a new fuel delivery system while I'm at it, as the old system is in dire need of an upgrade.
Any thoughts/opinions would be greatly appreciated! |
1 Attachment(s)
no need for the fass or airdog setups as your ve pump can only handle about 18 psi max inlet fuel pressure. 15 psi is the safe upgrade. install a mechanical piston pump in place of your stock diaphragm lift pump. can piece together the whole setup for around $120. pump on eBay and rest of the pieces from Cummins Parts | Engines | New & Remanufactured
pump i use Ebay ads not allowed on DTR and rest of the parts you'll need Attachment 49840 |
Originally Posted by j.fonder
(Post 3297657)
pump i use Ebay ads not allowed on DTR and rest of the parts you'll need http://i211.photobucket.com/albums/b...1New_Parts.jpg |
Originally Posted by jruthven
(Post 3297659)
Can you see a noticeable difference in terms of fuel pressure/delivery with that upgrade j.fonder? I initially leaned towards fass/airdog due to the fact that it bypasses all factory fuel lines, which have seen better days on my truck. Did you by chance upgrade your fuel lines along with the pump upgrade?
i still have factory lines from the lift pump to tank. i do however drill my banjo bolts slightly larger whenever i remove one. not sure it helps, but i figure why not. if you like spending money and relying on an electric pump, then go with the fass. but for 1/4 the cost, better reliability, and more fuel than you'll ever need, i'll stick with the piston pump. edit: yes, its a noticeable difference. pulls harder on the top end. stock pump is ~5 psi, piston pump is set at 15psi |
X2 Fass electric pumps being a waste of cash and time on a VE pumped 12V.
Install the piston lift pump would be my call as well, as pictured above by j.fonder. |
(Post 3297660)
well in this setup you're replacing the line from the lift pump to injection pump. if your fuel lines are bad, you'll have to replace them whether you use the piston pump or fass. meaning you can run a new line from tank to piston pump just as easily as you can from tank to fass.
i still have factory lines from the lift pump to tank. i do however drill my banjo bolts slightly larger whenever i remove one. not sure it helps, but i figure why not. if you like spending money and relying on an electric pump, then go with the fass. but for 1/4 the cost, better reliability, and more fuel than you'll ever need, i'll stick with the piston pump. edit: yes, its a noticeable difference. pulls harder on the top end. stock pump is ~5 psi, piston pump is set at 15psi Thanks for the info! |
(Post 3297665)
They supply more than enough fuel flow and pressure for a 1st gen.
They are also pretty cheap and I have seen them go 250,000 miles dozens of times. Fass / Air Dogs electric pumps are neither cheap or that reliable. I have gone through three Air Dog electric pumps [it is ready for another judging from the groaning it is making] in 130,000 miles on my 24V '01. |
I have never had an electric fuel pump on anything that was reliable.
I went with a Beans fuel sump, 1/2" lines all the way through the whole system, a 2nd gen Carter plp to an Aeromotive bypass regulator. I can't pull it less than 10 psi no matter what i do. Love it. I've got almost as much as an Airdog in my setup but went with Vulcan Performance high flow fittings at every connection as well. Plus it's mechanical. I hate writes lol
Originally Posted by Vader93
(Post 3297692)
(Post 3297697)
Vader93, what did you go with as far as your fuel line goes? There are so many options, was just curious what you installed.
been very pleased with my hungry diesel piston lift pump.
(Post 3297659)
(Post 3297657)
pump i use Ebay ads not allowed on DTR and rest of the parts you'll need http://i211.photobucket.com/albums/b...1New_Parts.jpg __________________ |
