Adjust your bands, shift points, and line pressure (pics)
Old Mar 29, 2012 | 06:53 AM
  #76
Jim5870's Avatar
I did this last week, definately an improvement.
Old Jul 15, 2012 | 11:37 PM
  #77
nivlek's Avatar
I just serviced my 92 3500 CTD with a 518 tranny.
Started by using a cordless drill to drain the pan...then brazed on a 1/4" pipe coupling and plugged it with a 1/4" pipe plug.
Next I adjusted the bands using a new torque wrench...the road test revealed that on the 1-2 shift, the truck began to slow down, as if the 1st gear was not releasing. I called an experienced friend who recommended not usinf the torque wrench, but instead tighten the bands just enough to take the slack out of the bands, THEN back off the prescribed amount, and then tighten the jam nuts. IT WORKS!!! my friend told me that he saw the guys at Turbo Action actually doing this on their racing trannies. It works like brand new!
Nivlek
Old Jul 16, 2012 | 05:30 AM
  #78
jughead's Avatar
Nivlek
i have been telling people this for years. no got to go by the book. the dang book is a starting point most vehicles can be improved by changing book settings one way or the other.
Old Jul 16, 2012 | 08:09 AM
  #79
ClassA4x4's Avatar
. . . I called an experienced friend who recommended not usinf the torque wrench, but instead tighten the bands just enough to take the slack out of the bands, THEN back off the prescribed amount, and then tighten the jam nuts. IT WORKS!!! my friend told me that he saw the guys at Turbo Action actually doing this on their racing trannies. It works like brand new!
Nivlek
Does it mean the adjustment is "looser" than that of the torque wrench tightness?
Old Jul 16, 2012 | 09:22 PM
  #80
sootnsmoke's Avatar
I am curious if this method would be the same for the 47RE trans and a 727 3 speed auto as well?
Old Dec 11, 2012 | 01:01 PM
  #81
Tori's Avatar
Me too. I'd like to know if this is the same procedure for an '03
Old Dec 11, 2012 | 09:50 PM
  #82
samiam4's Avatar
Mine's been rebuilt-
Looking at the available bands- it would seem that there could be different needed torque depending on lining material and style of band- split vs solid.
Old Jan 11, 2013 | 03:41 PM
  #83
LeviMXUSMC's Avatar
I could definatly use to do this since now I have lifted and put 35X12.50's on. I miss the low end pull and TQ.
Old Jan 11, 2013 | 10:57 PM
  #84
dzl_damon's Avatar
The pictorial was taken on a 3 speed 727. An A518 (46rh) is merely a a 727 with an OD bolted onto it. When I did the same procedure to my 93's A518, it was exactly the same.
Other transmissions, I have not looked at and can not comment, sorry.
Old Jan 12, 2013 | 01:25 PM
  #85
cougar's Avatar
What is the possibility of drilling and taping a small hole in the side of the case for a ball end allen to access the line pressure adjustment?
Sure save a lot of time and trouble.
I got my transmission rebuilt, but I don't think the guy actually checked and adjusted the line pressure. It doesn't seem to be much better than it was.
Old May 7, 2013 | 03:58 PM
  #86
wisconative's Avatar
I wonder how these folks are doing after these adjustments?
Anyone care to give an update?
Old May 7, 2013 | 04:02 PM
  #87
1STGENFARMBOY's Avatar
I did mine 2 years ago and all is great, well other than my super slippy converter.
Old May 7, 2013 | 04:45 PM
  #88
blackbox 91.5's Avatar
I would like to say thank you to dzl_damon for this excellent writeup. I just purchase a 91.5 and the transmission was slipping badly so i decided to try this, well my transmission does not slip anymore. The only thing I did different is 2.5 turn to the pressure side and i did not touch the TV screw, I just adjusted the bands and the TV cable to spec. You just saved me a re-built for later. thanks again.
Old Oct 15, 2013 | 02:41 PM
  #89
ClassA4x4's Avatar
Originally Posted by Fred Swanson
1 full turn is only 3psi. For a bone stock tranny, you don't want to go over about 70psi for base pressure(make sure your kick down cable isn't too aggressive, as this will show a higher pressure at idle), without updating the inner seal on the forward drum(3rd gear apply).
Your base pressure is most likely around 50-52psi, so 3 turns isn't going to kill your tranny, if you're at the stock base pressure.
On aftermarket VB's for some fun and towing, I set the base pressure to 80-85psi. All out race, 95+ for base. For the blue loctite screw, don't go below .800.
This .800, is it a .8mm feeler gauge between the screw tip and the throtte ever tang?
Old Oct 15, 2013 | 03:33 PM
  #90
jughead's Avatar
line pressure
been working on these things for 40 years have yet to blow any seals in the 3rd gear clutch drum. have actually blown the snap ring out and took the snap ring groove with it and the seal was still usable. i just dont understand
