AC issue
Old Jun 10, 2011 | 10:54 AM
ocoiro's Avatar
AC issue
I am working on my fathers 1991 Dodge D250 AC. The truck has a 5.9L diesel and the AC runs constantly, there are no bubles in the site glass, the low side pressure is 90psi, and the highside is between 90 and 100psi.
I am trying to determine if I have a bad thermoststic clutch cycling switch, as stuck expansion block, or a bad compressor. The factory service manual says to check the clutch cycling switch for continuity and I can not find any description of which combination of the three pins on CCS should have continuity or if all should.
Can anyone explain what I the real test procedure is for check continuity of the CCS?
dan123dbl
Feb 13, 2015 05:47 PM
DDysput
May 5, 2004 07:44 AM
ramlovingvet
Nov 21, 2002 06:51 PM
DieselDaze
Oct 30, 2002 12:07 AM
