Ac condensor removal?
Im currently pulling my engine out to fix a bunch of oil leaks and do some other odds n ends. My problem is I've only removed an engine an old jeep before which did not have an ac system. My question is what is the best way to remove the condenser and the refrigerant from the system?
Everything I've read said to take it to a ac shop. Well the trans, tase and and most of the front end is off and the truck is on jack stands so its too late for that. My primary concern is not to damage the system, as my ac works decent. Any advice is appreciated? |
Yes you have to discharge the AC system to remove the condensor, any way you can go the work without removing it? You'll have to get it re-charged once you have it all back together.
I don't think so. I'm going to be boxing the frame in the front and a bunch of other stuff. So I really need the work space.
Originally Posted by qmikep
(Post 3344890)
Everything I've read said to take it to a ac shop. Well the trans, tase and and most of the front end is off and the truck is on jack stands so its too late for that. My primary concern is not to damage the system, as my ac works decent. Any advice is appreciated? Expel the oil out of the compressor and replace it with new oil. Edwin |
(Post 3344902)
Just let the refrigerant out.
I always just release the refrigerant into the stupid atmosphere but, I like to put my face directly in front of it and then scare the kids with "Old-Man-Frosty-Face". -Niemand |
(Post 3344902)
Just let the refrigerant out. Plug the tubes to keep out dirt. You'll have to refill it with R-134a unless you use the R-12 substitute. I would flush it with the flush chemical and replace the dryer and maybe the expansion valve. They are fairly cheap parts. See the Sticky on Refresh your A/C system.
Originally Posted by N. Besonderes
(Post 3344905)
-Niemand Governor Moonbeam can kiss my A$$! |
Also best not to vape in the area of the release.
As a card carrying member I cannot condone it. However when I used to work for the county, it was common practice to vent it into the pit, But these were small systems and only held 45 pounds of R-22. Since it is heavier than air on occasion I found mechanics who hid out on the connecting tunnels to smoke unconscious. |
(Post 3344902)
Expel the oil out of the compressor and replace it with new oil. Edwin Cools better than R134, pressures lower than R134, and as a bonus leaks less. Cost of course is dirt cheap compared to R12. As far as safety, most of Europe is going to propane refrigerant after extensive safety studies. |
