91 owners manual/Cruise control
Old Jun 14, 2003 | 12:04 AM
carl20320's Avatar
Does nayone happen to have one? I hear there is a good section on troubleshooting the cruise control in there. Mine no longer works. The switches and fuse are good, the brake switch is fine. It quit working after some ABS brake work but no idea why. Everything seems to be hooked up OK.
If you have the manual, I would grealty appreciate if someone could scan and e-mail me the pages at carl20320@adelphia.net
Also any ideas on where else to start looking for the problem would be greatly appreciated.
Carl
Old Jun 14, 2003 | 01:17 AM
turbodiesel_ram's Avatar
Re:91 owners manual/Cruise control
Ebay would be a geat source for finding the '91 owners manual. I have seen all years pretty much represented there.
Old Jun 14, 2003 | 01:36 AM
carl20320's Avatar
Been looking and no luck so far. Thanks though and I will keep looking.
Old Jun 14, 2003 | 07:28 AM
jw216's Avatar
I got mine here.<br>www.techauthority.damlerchrysler.com<br>
Old Jun 19, 2003 | 12:40 AM
carl20320's Avatar
Unfortunately, they only go back to 92. I found a service manual on e-bay. I hope it helps!<br><br>Carl
Old Nov 1, 2003 | 01:45 AM
astromybud's Avatar
Did you ever find anything with the cruise control?
Currious
Astromybud
Old Nov 2, 2003 | 10:38 PM
carl20320's Avatar
No I haven't. I'm beginning to think I have a problem in my clockspring in the steering column. The switches test fine when I have them out of the wheel but when I measure at the 60 pin connector, I am missing voltage from one switch.
Carl
Old Nov 4, 2003 | 01:47 AM
jw216's Avatar
Carl, you could very well have clockspring problems, mine was broke at one end. It says non-serviceable unit on it. One dealer wanted $132 and another wanted $107. So I took it apart and melted about 1/4&quot; of the coating off the flat wire with soldering iron and then resoldered them back where they went and now cruise works great.
Vader93
Jan 7, 2015 07:27 PM
newhouse
Feb 16, 2012 09:39 PM
elephantrider
Jan 30, 2012 09:58 AM
ILLINOISRAM
Jan 9, 2008 05:19 PM
12valve@heart
Sep 8, 2006 06:06 PM
