89 W250 Mechanical Speedometer Cable Questions
Old Jun 8, 2008 | 01:03 PM
Trebor's Avatar
What specific parts were installed between the NP205 transfer case and the mechanical speedometer in an 89 Dodge W250? RockAuto lists a lower cable to a sensor and an upper cable. Was there a one piece cable for the 5 speed trucks? Was there any sort of gear reducer or direction changing component that attaches to the transfer case? What parts do I need? Other than at a junk yard, where would the best place to find them? Anyone have Autozone, Carquest, NAPA part numbers, etc? Thanks.
Old Jun 8, 2008 | 11:40 PM
BearKiller's Avatar
If your truck was 2wd, I could maybe help you, as I went through all of that getting the 89 Getrag spliced to my Ford speedo.
I can't vouch for the 4wd set-up; but, I do know for a fact that the 2wd MUST HAVE the adapter gizmo that screws into the transmission; because, the adapter REVERSES the direction of rotation.
This gave me fits for weeks, until I noticed that my odometer was running BACKWARDS, taking miles off of my truck, while the speedo needle layed un-moving on zero.
I took apart the adapter that I had, milled a replacement gear-drive-shaft, and re-assembled; once installed, my speed and odometer are now dead on the money.
I don't know just exactly what year they quit the cable speedo, but the cables are way ahead of that troublesome electric mess.
Old Jun 9, 2008 | 07:11 AM
PapeCAT's Avatar
yeh took me a while to figure that one out too till I noticed the speedo was working in reverse :-)
Old Jun 10, 2008 | 05:17 AM
Trebor's Avatar
Was the speedometer "gear reverser" setup used on all NP205 transfer cases including W250's & W350's including trucks with gasoline engines?
90firstgen
Apr 13, 2008 05:48 AM
Kirk T
Sep 20, 2006 07:19 AM
edwinsmith
Dec 7, 2004 12:35 PM
TexasHardcore
Aug 29, 2004 12:20 AM
hellotbone
Oct 7, 2003 06:54 AM
