4x4 frame
Old Jun 24, 2007 | 10:29 PM
LOGAN's Avatar
Muted User
4x4 frame
i found a late 70's to early 80's 4x4 frame, its a dually with a flat bed thats got a junk cab which means it has a 60 front and 70 rear, if i can get it cheap enough i am thinking of swapping my body and engine into it, what is the biggest thing im gonna run into, if the truck is a 4-speed manual, will i have to get a bellhousing for the cummins specific pattern or can i use the stock one, i am gonna let the guy keep the cab, bed, and motor. if need be, i will just use my 2wd 727 until i get enough time to put the t-case and driveshaft and stuff in.
Old Jun 25, 2007 | 09:38 AM
LOGAN's Avatar
Muted User
no one knows???
Old Jun 25, 2007 | 10:25 AM
Free89W350's Avatar
The only thing that I can think of is if it is a Cab & Chassis frame it might be longer. You might want to do a little cyber space digging and see if you can find any chassis specs on that year truck and compare them to yours. Depending on what you come up with it might just be a matter of hacking a little off of the rear frame rails or it just might be a really involved project. Hope this helps out. Ryan
Old Jun 25, 2007 | 10:44 AM
LOGAN's Avatar
Muted User
if its a cab and chassis i will probably still buy it cause i really want the 4x4 and ill figure out everything after that.
Old Jun 29, 2007 | 01:09 PM
simplysmn's Avatar
pretty much everything should bolt right onto that frame bed part of frame may need trimming
Old Jun 30, 2007 | 06:40 PM
EClancy's Avatar
yer motor will not bolt to a gasser 4spd, much less hold up to the engine.
if you want to get rid of that gassr 4spd, let me know....i've been looking for one
Tyheethan
Feb 25, 2009 12:12 PM
gts95
Aug 27, 2007 10:13 AM
V.R.Wheeler
Aug 4, 2007 01:00 PM
95black2615
Dec 20, 2006 06:37 PM
ptgarcia
Sep 12, 2006 06:04 PM
