3200 gov spring only
Old Jun 14, 2006 | 07:07 AM
Lightweight's Avatar
Hi Folks
I will be installing the new spring in my pump soon and was wondering?
If I do nothing but install the spring, what if any, other adjustments will be needed.
GW
Old Jun 14, 2006 | 09:19 AM
timb's Avatar
You should'nt have to do any other adjustments yet.But after you feel the differnce, you will want to do the others.
Old Jun 14, 2006 | 09:32 AM
Thank you
I read the tech post about this but didn't find or understand it to say there would be none. Thanks for clearing it up.
GW
Old Jun 14, 2006 | 10:31 AM
G1625S's Avatar
Just remember to mark all your settings before installing the spring. The throttle shaft index needs to be noted since that linkage has to come off to do the install. Also, the full power screw must be removed, or at least backed way out, to get the pump top back on, so in order to end up where you started, that setting will also have to be noted.
Old Jun 14, 2006 | 12:14 PM
Thanks G1625S
I printed the install from the tech guides here. Without this site and the folks here----- well I for one, would be lost , or at a shop all the time.
GW
Old Jun 14, 2006 | 12:21 PM
Boatnik's Avatar
That would be a good time to remove the tamper resistant collar on the power screw, and dress up the threads.
fishin fever
Mar 13, 2006 06:46 PM
racermatt2606
Jan 14, 2005 06:56 PM
adamroofer25
Jun 28, 2004 03:36 PM
Tommy93w350
Jan 30, 2004 10:30 AM
Jim Shulmister
Mar 8, 2003 09:07 AM
