2WD Front Springs PN
Old Sep 12, 2007 | 10:49 AM
Jim5870's Avatar
Does anybody have the part number for replacement front springs
for a 2WD?
Thanks, Jim
Old Sep 12, 2007 | 11:12 AM
BC847's Avatar
1st Generation Admin
Dodge part number(s) ~
4447 351 - 1200/1340 lbs. (SJC)
4447 352 - 1300/1400 lbs. (SJF)
4447 353 - 1400/1500 lbs. (SJK)
4447 354 - 1475/1615 lbs. (SJP)
4447 355 - 1500/1650 lbs. (SJR)
4447 356 - 1550/1700 lbs. (SJU)
4447 357 - 1725/1915 lbs. (SKB)
5203 8360 - 1825/2000 lbs. (SKG)
NOTE: Spring ratings are listed as Pad/Ground Capacity and Sales Codes.
4322 629 - SPACER, frt. suspension coil spring (for added height).
4089 580 - ISOLATOR, frt. spring (for added cushion).
NOTE: These numbers are from the August, 1992 Dodge Parts Book and may have been superseded since.
Hope this helps more than confuses.
Old Sep 12, 2007 | 05:05 PM
TJE's Avatar
TJE
I just put a set on my truck that I got from Napa. They are severe duty. I didn't want to have to do them again. I forget the brand name, but the number for them is listed below. Thanks, Tony
NCP 2773276
I got this off the Napa website.
Old Sep 12, 2007 | 08:41 PM
sdstriper's Avatar
Moog 7226
And I believe there is another heavier spring Moog has with an additional letter on the P/N. Someone else have that info?
Old Sep 12, 2007 | 10:05 PM
92DuallyCTD's Avatar
Originally Posted by sdstriper
Moog 7226
...would be Moog 7226-S(guessing S is for Severe Duty?)
Advance Auto Parts similar numbers; 5716 Heavy Duty(standard), 5716-S Severe Duty. Seeing a pattern here...
signature600
Mar 29, 2009 12:57 PM
Greguw
Apr 8, 2006 10:17 AM
pecandude1
16
Oct 11, 2005 08:35 AM
TexasHardcore
May 19, 2005 01:50 PM
bigred496
Oct 22, 2004 07:16 PM
