2WD Front Springs PN
Does anybody have the part number for replacement front springs
for a 2WD? Thanks, Jim |
Dodge part number(s) ~
4447 351 - 1200/1340 lbs. (SJC) 4447 352 - 1300/1400 lbs. (SJF) 4447 353 - 1400/1500 lbs. (SJK) 4447 354 - 1475/1615 lbs. (SJP) 4447 355 - 1500/1650 lbs. (SJR) 4447 356 - 1550/1700 lbs. (SJU) 4447 357 - 1725/1915 lbs. (SKB) 5203 8360 - 1825/2000 lbs. (SKG) NOTE: Spring ratings are listed as Pad/Ground Capacity and Sales Codes. 4322 629 - SPACER, frt. suspension coil spring (for added height). 4089 580 - ISOLATOR, frt. spring (for added cushion). NOTE: These numbers are from the August, 1992 Dodge Parts Book and may have been superseded since. Hope this helps more than confuses. ;) |
I just put a set on my truck that I got from Napa. They are severe duty. I didn't want to have to do them again. I forget the brand name, but the number for them is listed below. Thanks, Tony
NCP 2773276 I got this off the Napa website. |
Moog 7226
And I believe there is another heavier spring Moog has with an additional letter on the P/N. Someone else have that info? |
Originally Posted by sdstriper
(Post 1692465)
Moog 7226
And I believe there is another heavier spring Moog has with an additional letter on the P/N. Someone else have that info? Advance Auto Parts similar numbers; 5716 Heavy Duty(standard), 5716-S Severe Duty. Seeing a pattern here...[coffee] |
