2nd gen intercooler in 1st gen?
Old Nov 28, 2009 | 06:53 PM
2wdcumns247's Avatar
has anybody done a second gen intercooler in a first gen if you have how have u done it
Old Nov 28, 2009 | 07:00 PM
peobryant's Avatar
This may help you.
https://www.dieseltruckresource.com/....html?t=186908
Old Nov 28, 2009 | 07:03 PM
you are a life saver thanks i picked one up today and every one tells me i cant do it do you have to cut the frame at all
Old Nov 28, 2009 | 07:26 PM
No the 3rd gen intercooler you have to cut the frame.
the 2nd gen one will work and be a HUGE improvement over no i/c
Old Nov 28, 2009 | 08:09 PM
when i set my intercooler on the frame it sticks 8inchs above the radiator so how do i do this
Old Nov 28, 2009 | 08:24 PM
Riflemanusmc's Avatar
Registered user
Follow the sticky at the top of the forum. VERY indepth and will explain everything for you. There is a fair amount of fitting to be done. Its not that bad..
Old Nov 28, 2009 | 08:39 PM
Trooperthorn's Avatar
Are you sure what you have is a 2nd gen intercooler? They are really not much taller, if any, than the 1st gen.
Old Nov 28, 2009 | 08:49 PM
im not sure the guy i got it from said it was a second gen one but idk
Old Nov 28, 2009 | 08:50 PM
peobryant's Avatar
Take a couple pictures of it and post 'em up. We can tell you what it's from.
Old Nov 28, 2009 | 09:04 PM
the dimensions are 28x25" roughly
Old Nov 28, 2009 | 09:06 PM
do you have to move the ac or oil cooler or any of the coolers
Old Nov 28, 2009 | 10:02 PM
Registered user
Simple. Measure the height. 2nd GEN 12V. 15.5 tall. 2nd GEN 24V 16 inch tall. That would be AS mounted from top to bottom. That should give you what you need to know for spec's on what you have, to what you need. Your AC will be fine...
Old Nov 28, 2009 | 10:45 PM
it must be a 3rd gen one then
Old Nov 29, 2009 | 04:19 PM
92roughstock's Avatar
2ndGen inlets- close to the bottom/ top, depending on how you mount it.
3rdGen inlets- near the center, top to bottom.
Old Nov 29, 2009 | 05:16 PM
DNRCustoms's Avatar
u must have a different one. here is what a 2nd gen one should look like..
Here is what my 2nd gen install looked like
https://www.dieseltruckresource.com/...s-t216800.html
