1991 fuel module
The fuel module in tank is rusted up. Part steel and plastic. Steel part is gone. I guess it is obsolete. Does anyone have any ideas? I seen some on ebay the part number is 4798671 from mopar it says fit 96-98. Does anyone know if it will work? The screen in bottom is shot also. Any help appreciated.
Originally Posted by A.Spagnuolo
(Post 3263412)
I doubt if the second gen will work, but you never know. Also if your lines are the issue ( rust ), are they inserted thru a rubber bung like the second gen is? If so, a draw straw might be an option. |
can get pic to load.
I am not sure what to do. The one i listed for second gen looks just like it. looks like i could use parts from it to fix mine but it 340.00 |
As far as i know they are the same... heck if you look at the late model trucks the collar that holds them down appears to be the same. In my rclb to ccsb conversion i bought my "module" on fire welding (durh should have protected.. i know better but was being lazy) and the supply return plastic knob is the same on the gassers as the diesel... I even looked into getting a whole 2nd gen module but in the end get the piece i needed for 1$ at the pick an pull here. Proceed with caution but i am fairly certain they are the same. I mean with could change? both are diesel and have mechanical pumps....
good luck |
Originally Posted by lockgessner
(Post 3263479)
good luck |
Originally Posted by patdaly
(Post 3263440)
Can you post a pic of it?
i am going to try the one for 2nd gen. I can send it back if it dont fit.
I was going to replace fuel lines. They are metal now should i replace with rubber ones or what? I got all kind of rust in my fuel filter which caused truck not to run. It came from the module that rusted up. thanks |
(Post 3263490)
the one i listed worked with a few mods. It says its for 96-97 trucks.
A little late, but I replaced my fuel lines with nylon lines. My 91.5 had steel lines, but rubber hose adapting them to newer-style quick-connectors at the tank, so its not that hard to convert over to completely new style lines/hardware. The '90's I've seen would require a nylon style barbed coupler to adapt to rubber to go to the steel inlet & outlet on the tank.
That was years ago, it works well, and the nylon, obviously, doesn't rust like the original. |
