14" front d60 brake upgrade, and rear too.
Old Jun 3, 2017 | 08:52 AM
sooty's Avatar
anyone done the 2009 up dodge 3500 dual piston caliper and rotor upgrade? im curious what master cylinder would suffice, torq axle is making brackets, the caliper also needs to be sourced with its own bracket, hub will need to be turned to clearance rotor id, I think hydraulic lines stay stock, calipers are same for 2wd also. wheel clearance will also be an issue. im in the long term process of fabbing rear dual piston inner e-brake rears too, my mock adapter has studs through d70 axle flange, 1-1/4" spacer to studs through caliper bracket. e-brake drum is deep and requires offset. im still using vacuum booster ad hoping not to go hydraboost.
Old Jun 4, 2017 | 01:35 PM
cabtruck's Avatar
Im doing a 3rd gen brake upgrade as far as master cylinder goes get a third GEN hydroboost and master cylinder drill one hole in your firewall and you're done
Old Jun 4, 2017 | 02:30 PM
kevin93's Avatar
Pictures and more info on this would be great.
Which is probably obvious.
Old Jun 4, 2017 | 11:38 PM
gyman98's Avatar
Just another obvious point, 17"+ wheels would need to be used
Old Jun 5, 2017 | 12:58 PM
u2slow's Avatar
Here's the Torq brackets...
D60 14 in Big Brake Brackets - Torq Axle
Here's two samples of how to swap OEM rear discs onto a drum axle...
Pirate4x4.Com : 4x4 and Off-Road Forum - Powered by vBulletin
fordmann.com | F-350: Sterling Rear Disc Conversion
Old Jun 13, 2017 | 10:35 PM
samiam4's Avatar
I'd love to do a complete gen 3 brakes.. can I do the d25000 2wd front suspension too! What is the I'd of the wheel needed??
BC847
Feb 26, 2019 07:13 PM
SeaW250
Dec 24, 2014 01:30 PM
redneck_ram
Oct 29, 2012 04:45 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
Bobcat698
Sep 26, 2005 12:19 PM
