13mm wrench for pump
Old Dec 5, 2011 | 03:08 PM
td3620's Avatar
Exclamation 13mm wrench for pump
Anybody got a pic of a 13mm wrench that's bent
Old Dec 5, 2011 | 03:37 PM
BILTIT's Avatar
Bent for what?
Old Dec 5, 2011 | 03:53 PM
maybe368's Avatar
i don't know what year your truck is, but the early type vac pump and power steering pump are held on by 2 bolts, IIRC. It was a lot easier to remove the bolts and let it drop down, out of the way. Also, a quarter inch drive socket with a wobble extension gets to it...Mark
Old Dec 5, 2011 | 03:54 PM
maybe368's Avatar
Originally Posted by BILTIT
Bent for what?
I think that he's talking about the hidden IP bolt...Mark
Old Dec 5, 2011 | 04:27 PM
Just buy a 13mm S-Wrench
Old Dec 5, 2011 | 05:20 PM
BC847's Avatar
1st Generation Admin
Good luck finding some.
Just recently purchased some for my Son's birthday. The only S-shaped wrenches I could readily find were from Sears.
Plan "B" is to buy some crescent wrenches (C-shaped). They work just as well.
Old Dec 5, 2011 | 05:41 PM
BILTIT's Avatar
Will a moon wrench work?
http://buy1.snapon.com/catalog/item....5&group_ID=549
Old Dec 5, 2011 | 05:45 PM
maybe368's Avatar
probably, but for 40 bucks, I'll remove the 2 bolts...Mark
Old Dec 5, 2011 | 05:52 PM
twichit's Avatar
the blue point wrench for the ve pump bolts was about $35-6 when i got mine .... and its made JUST for the ve bolts
Old Dec 5, 2011 | 06:02 PM
92betsy's Avatar
I got a set of wrenches from harbor freight for around $10 10mm-19mm s-wrenches. Work great whenever I screw with my pump' timing.
Old Dec 5, 2011 | 06:25 PM
sooty's Avatar
i heated one up with the torch to bend it, works great once your on the bolt
Old Dec 5, 2011 | 07:15 PM
td3620's Avatar
to get to the back bolts on the injector pump
Old Dec 5, 2011 | 07:22 PM
td3620's Avatar
thanks,92 betsy
Old Dec 5, 2011 | 07:47 PM
dieselJon's Avatar
Moon shaped are not bent enough.
Harbor Freight has them. Also O'Reillys has a ratcheting set but at $200, I will pass.
Old Dec 5, 2011 | 07:52 PM
Exekiel69's Avatar
Torch
