03 turbo?
Old Nov 13, 2008 | 10:26 PM
soggy's Avatar
03 turbo?
i have the chance to pick up a stock turbo from an 03 reg output cummins, is that an hx-35? anyone have specs?
Old Nov 14, 2008 | 08:24 AM
93Fury's Avatar
It will be an HY-35 or an HE341, I do believe.
Old Nov 14, 2008 | 10:03 AM
turboguy121's Avatar
03 is a HE351 will work same as a HY35
Old Nov 14, 2008 | 01:45 PM
93Fury's Avatar
Ooops, wrong button. Meant to put 351.
Old Nov 14, 2008 | 08:08 PM
soggy's Avatar
so is it the tiny 9cm housing? with the mods in my sig i can hit 1600* F pretty easily so im wondering if this would flow a little more air? thanks guys
Old Nov 14, 2008 | 08:51 PM
SuperiorRam's Avatar
HE341 is the CORRECT ANSWER with the 9cm housing and it flows as good or better than a 12 on a hx go to the third gen High Performance selction and search for "turbo Vs turbo" the 03 early 04 is the 341 the 04.5 to 07 (5.9) is the he351 which is way more disireable.
Old Nov 14, 2008 | 08:55 PM
rich's Avatar
used the 03 turbo when we dropped a 96 12v in the 03 it spooled up fast but would have a pretty high egt all had was 50hp injectors and the pump and timing was advanced and i would hit 1400 and up pretty easy
Old Nov 14, 2008 | 10:12 PM
vwjunkie53's Avatar
So are the turbos off a 04.5 to 07 5.9 a good upgrade? How does that mount up, the turbo is oriented downward instead of on top of the manifold... Do you swap to a 24v manifold?
Jason
Old Nov 15, 2008 | 07:52 AM
I believe its a bolt on, no manifold switching.
If i remember correctly, the 351 has a 60mm comp. wheel compared to stock 56mm, if the turbo is more then 250 i wouldnt buy it.
but also has an electronic computer wastegate.
Old Nov 15, 2008 | 11:39 AM
vwjunkie53's Avatar
Anyone have a pic of one on a 1st/2nd gen 12v? I can't see how that would work with the orientation of the turbo...
Jason
Old Nov 15, 2008 | 12:06 PM
DaveB.inVa's Avatar
You might want to talk to Big Blue 24. He has a HE351 on his 2nd gen 24V and it works well for him. He posted some pictures in a thread once and basically he had a pipe bend up to transition between the outlet of the turbo and the intercooler.
https://www.dieseltruckresource.com/...d.php?t=203242
If you're running a non IC 1st gen you could certainly have pipe bent to run a HE351. I saw a Cummins dragster in Diesel Power that had the pipe bent to run around the front of the engine so as to avoid the valve cover then straight into the intake.
There once was a video on youtube with a 2nd gen running an HE351 too. They kept calling it an HX40 though and sadly they deleted the video. They used a straight 90 elbow on theirs, not the greatest for airflow. Blues is bent up nice though with good sweeping bends, as best as could really be done in the area he had to work with.
I looked a bit... here are the pics of his install.
https://www.dieseltruckresource.com/...turbo+pictures
Old Nov 15, 2008 | 02:44 PM
vwjunkie53's Avatar
Cool thanks for the link
Jason
Old Nov 15, 2008 | 03:02 PM
vwjunkie53's Avatar
Man that sounds like the way to go! Why spend the money on a 60mm compressor upgrade on an old h1-c when you can score the whole edit turbo for that or less and have a nicer setup that will spool better to boot!
I think thats on my mods list now...
Jason
Old Nov 15, 2008 | 03:46 PM
Jason
Gotta deal with the wastgate deal. a 60mm h1c compressor upgrade and 12cm housing is definely easier. May not spool as fast as a 351 .but......
Old Nov 15, 2008 | 04:46 PM
soggy's Avatar
so what about the he341? any good for the 1st gen? w/ my mods
