$10 fuel shutoff solenoid
So has anyone ordered their fss solenoid from here? Will this work? Paid over $90 for mine, but it's still sitting at Napa, so I can still return it. What to do?
http://dieselvw.com/PumpSolenoid.htm
Got it from here:http://www.dieselbombers.com/1st-gen...-silenoid.html
Thanks!
Thanks!
I haven't had to replace mine ...YET! Mine did mess up and it wouldn't start, so i pulled the little rubber tip out and spring...it fired right up, but of course wouldn't stop with the key. Most of the problems that I have read is if it goes bad then it won't start or just dies while driving. Mine was wiring problem.
Schamran, buy that one!! they work great.
Take the $90 one back.
This topic comes up once-twice a month. Don't buy the shutdown solenoids from Napa or anything, they're all the same and the $10 one from VWparts.com works beyond good
Tags- shutdown solenoid, shutoff solenoid
Thanks!
Thanks!
When yours gave up the ghost? Did it just not start or not shut off?
Thanks!
Thanks!
You know that bracket comes off with like 3 allen head screws right? No need to cut it and risk damage to your lines. I think it's got something to do with adjusting timing (like a special tool hooks onto it to lever the pump but I could be wrong).
Try changing the fuel solenoid on the side of the road with that bracket in original condition. If you ever have to do that you will wish you modified the **** thing. I do suggest you remove it to cut it down a bit.
