What Happen??
Old Feb 11, 2008 | 07:16 PM
deereguy07's Avatar
What Happen??
Ok I lost 5th gear in my 97 the other night. I drove it on to the house i 4th. About 25 miles or so. I left it parked till I could haul it to a friends shop. Got the truck to the shop yesterday. Got everything out and fixed 5th gear. We left the trans in the truck and jus took the back cover off to fix it. I looked at the gear when I took it off and it was fine. No chipped teeth or odd wear. Put the new nut and washer on and put everthing back together. Put new oil in the trans and transfer case. Was gonna pull it out of the shop and try it out. Made it about 300 yards and went to shift from 3rd to 4th and the trans locked in reverse. 4 nice black marks in the road now. I think I was goin about 30 or 35 mph.(can't remember) I mash i the clutch and it still works properly. I can feel A detent still for reverse. When I put the shifter in 1st and ease out on the clutch it just boggs the motor. Same in 2nd also. When shifter is in the neutral position the trans is still in reverse and will still back up when I let out on the clutch then. Took the shifter out and as far as what u can see from the top everything looks and moves properly. I've only heard of this happening to one other truck. A bearin siezed up on the top shaft in that truck. Gonna take everything back out tomorrow night.
Do any of yall have any idea waht my trans could have wrong with it? Any help is very mush appreciated. Thank you
Wouldn't be as bad had I not bought the truck only about 4 weeks ago.
Old Feb 12, 2008 | 09:54 AM
infidel's Avatar
That's a new one.
Give the folks at Standard Transmission & Gear a call at 800-783-8726
They are very knowledgeable about our trannies and happy to help.
Old Feb 12, 2008 | 04:27 PM
TIMMY22's Avatar
Index Number Part Description
1 Speedo Drive Rotor
2 Mainshaft Overdrive Gear
3 Mainshaft Rear Bearing Cup
4 Mainshaft Reverse Washer
5 Reverse Mainshaft Gear
6 Reverse Mainshaft Sleeve
7 Needle Bearing
8 Reverse Gear Spacer
9 Retaining Ring
10 Reverse Clutch Gear
11 Mainshaft 1st & 2nd Bearing
12 Mainshaft 1st Speed Gear
13 Mainshaft
14 Clutch Gear
15 Mainshaft 1st & 2nd Snap Ring
16 Mainshaft Inner Synchro Ring
17 Mainshaft Center Synchro Ring
18 Mainshaft Outer Synchro Ring
19 Downshift Inhibitor Spring
22 Synchro Spring
23 Synchro Clutch Key
24 Synchro Block
25 2nd Speed Gear
26 3rd Gear Thrust Washer
27 3rd Gear Retaining Ring
28 Mainshaft 3rd Gear Bearing Spacer
29 3rd Speed Mainshaft Gear
30 Mainshaft 3rd Gear Bearing
31 Synchro Clutch Gear
32 Mainshaft Synchro Ring
34 Synchro Spring
35 Synchro Key
37 Maindrive Clutch Ring
38 Mainshaft Rear Thrust Bearing
39 Mainshaft Pilot Bearing
40 Maindrive Gear
41 5th Speed Synchro Sleeve
40 Maindrive Gear
41 Maindrive Bearing Cone
42 Countershaft Rear Bearing Cone
43 Countershaft Assembly
44 Countergear Key
45 3rd Counter Gear
46 Counter Drive Gear
47 Washer Selective
48 Countershaft Front Bearing Cone
49 Retaining Plate
50 Shim Selective Kit
52 Reverse Idler Gear Washer
53 Needle Bearing
54 Reverse Idler Gear
55 Spacer
56 Reverse Idler Gear Shift
57 Maindrive Retainer Assembly
58 Maindrive Oil Seal
59 Maindrive Bearing Cup
60 Countershaft Rear Bearing Cap
61 Countershaft Front Bearing Cup
62 PTO Cover
63 Case
64 Countershaft Rear Bearing Cup
65 Countershaft Rear Bearing Shim Kit
66 Countershaft Rear Thrust Washer
67 Needle Bearing
68 Countershaft 5th Bearing Spacer
69 Rear Countershaft Bearing Retaining Plate
70 Countershaft 5th Gear Clutch Hub
71 Countershaft 5th Clutch Sleeve
72 Countershaft 5th Synchro Ring
73 Countershaft 5th Clutch Ring
74 Snap Ring
75 5th Shifting Fork
76 5th Shifting Fork Shaft
77 Extension Housing
78 Vibration Dampener
79 Mainshaft Washer
80 Mainshaft Nut
81 Extension Housing Bearing
82 Snap Ring
83 Extension Housing Oil Seal
84 Propeller Shaft Yoke
85 Rear Output Spline Seal
87 Shift Lever Assembly
88 Shift Lever Cap
89 Seat Control Lever
90 Spring
91 Plug Expantion
92 Bolt
93 Dowel Pin
94 Bare Cover
95 Pin Interlock
96 Shift Fork Pin
97 3rd & 4th Shift Fork
98 Plunger Interlock
99 1st & 2nd Shift Rail
100 3rd & 4th Shift Rail
101 1st & 2nd Shift Fork
102 Spring Shift Finger Plunger
103 Plunger 1st & 2nd Bais Shift
104 Pin Spring
105 1st & 2nd Shift Lug
106 5th 5th Shift Lug
107 Reverse Shift Fork Pads
108 Reverse Shift Fork Pad Curved
109 3rd & 4th Shift Lug
110 Plunger Reverse Overdrive Fork
111 Reverse Inhibitor Bolt
112 Reverse Shift Inhibitor Assembly
113 Pin Reverse Inhibitor
114 Overdrive & Reverse Rail
115 Plunger Detent
116 Spring
117 Plug Shift Rail
118 Gasket Back Up Switch
119 Switch Back Up
120 Breather Assembly
121 Trunnion
122 Countershaft 5th Synchro Assembly
123 Mainshaft 1st & 2nd Synchro Assembly
124 Mainshaft 3rd & 4th Synchro
If you study this enough, you'll figure it out.
DodgeRamCO42
17
Nov 23, 2003 09:33 PM
AlpineRAM
Mar 23, 2003 01:46 AM
TxDieselKid
Mar 21, 2003 07:23 PM
Dave65
Jan 9, 2003 05:10 AM
