What is that big nasty tube?
One more question about this subject. If an engine had blow by due to needing a rebuild wouldn't it be smoking out the exhaust real bad? Or more then usual? My enigne is all stock and to be honest, it doesn't smoke much at all. Even at start up.
If adjusting the valves doesn't cure the blowing out the dipstick trouble, you can have a compression check done. That'll tell you more about the condition of the motor.
Also, there was a post recently about the vacuum pump dumping into the crankcase and causing excessive blowby, that could be your problem also.
ok
So while I was doing my vegetable oil conversion I removed the starter to better get to the lift pump, fuel preheater, and other lines. The tube you all are talking about fell out and hit me in the face. I shoved it back, couldn't get it to go, and just didn't worry about it. I figured if it was important they woulda put it on better. I guess now my engine will look like it is leaking oil? Any idea how to get it to go back on (if I can find the hose), maybe I'll put a longer one on to get it toward the rear of the vehicle.
Very enlightening discussion of how to acutally measure blowby. Thanks!
Scotty
Dec 8, 2004 11:11 AM
