Weak power
Old Jul 11, 2007 | 12:13 AM
capt.Ron's Avatar
I think I can... I think...
Weak power
I've noticed that my truck seemed kinda sluggish lately and today when I floored it it seemed to take a really long time before shifting into O.D. I pulled the K&N to clean it and it was really really filthy. Everything beyond it is clean and dry of oil so it must be walkin the walk. Anyway I dropped in a stock filter while letting the "drop in" dry. It's still pretty sluggish....my next guess is a dirty fuel filter.
Any reason to think that the ULSD is causing problems??
Old Jul 11, 2007 | 11:16 AM
gmctd's Avatar
Dirty fuel filter doesn't help, so good move on that - try some power service\equiv Cetane additive + 1/2oz ashless 2-stroke motor oil per gallon of fuel - see if that doesn't help a bunch
Old Jul 11, 2007 | 11:38 AM
capt.Ron's Avatar
Yea changing the fuel filter did a lot. When I floor it "unloaded" I would get about 28 psi in boost. After the fuel filter change I'm getting 35psi. with a stock air filter. I'll be putting my K&N back in now that it's dried.
I've run power service before.....never really noticed any difference. I run Howes "Meaner Diesel Cleaner" and I see a really big difference between running it or just straight diesel.
I think I'll add the outboard oil on my next trip to Wally World.
Old Jul 11, 2007 | 01:12 PM
frostytj's Avatar
You notice any increase in EGTs with your sluggishness prior to your filter change? Just curious as I am trying to track down a problem but the truck doesnt appear to be sluggish and the filter is not that old.
Old Jul 11, 2007 | 04:21 PM
capt.Ron's Avatar
Not really.
I have noticed an egt increase when air filter is plugged.
Old Jul 11, 2007 | 06:36 PM
clutch1's Avatar
when my fuel filter gets old it will do what you described, i can go WOT and the boost will fluctuate up and down
Old Jul 11, 2007 | 09:05 PM
kawi600's Avatar
Huh, do you run a fuel pressure gauge? Curious if you saw any differences in fuel pressure at the point performance dropped off a bit
Old Jul 12, 2007 | 12:12 AM
capt.Ron's Avatar
I don't have a fuel pressure gauge.
Old Jul 12, 2007 | 12:14 AM
capt.Ron's Avatar
After adding a pint of TCW-3 as well as changing the fuel and air filter things are much much better. I still have a lag off of the line but I've had that for a really long time. Not sure what to do about that problem.
Old Jul 12, 2007 | 03:56 PM
TexasHardcore's Avatar
I noticed my truck was starting to lose power as well. The smoke was more dark gray than black, EGT's were a bit hot, and it just didn't have the power it did a few days prior. It was time for a fuel filter change so I put a new one in today in the parking lot at work over my lunch break. Man, what a difference! The truck feels more powerful than ever, the smoke is solid black, boost is up a few notches, EGT's down a few.
My lift pump has also been clickity-clacking over the past month or so, and the filter change resolved that as well.
Amazing what a $30 filter and 10 minutes can do.
Old Jul 13, 2007 | 08:12 AM
frostytj's Avatar
Yeah I had just cleaned the air filter prior to posting but hadnt run the truck yet. That helped it out for sure. Might change out the fuel filter as well.
Idaho Guy
Jul 24, 2007 09:23 PM
joeinblueout4u
Feb 28, 2006 08:46 PM
Idaho Guy
13
Jul 26, 2005 09:24 AM
mopar2ya
Aug 26, 2004 12:23 AM
timdewaltman
May 15, 2003 10:30 PM
