water temp gauge going crazy
Old Oct 20, 2009 | 03:57 PM
war machine's Avatar
ok so I was driving along today, and looked at my guages to notice that the water temp gauge was going absoutley bezerk, flicking from one stopper to the other and fluttering in between, giving me no accurate reading at all. (these wernt slow movements).
I'm thinking coolant temperature sensor??? just would like an opinion from somone else, thanks, truck is in my signature, and this wasnt with any aftermarket gauges. (water temp gauge in the dash cluster).
thanks for your time.
Old Oct 20, 2009 | 05:32 PM
patdaly's Avatar
That or a loose wire.
Old Oct 20, 2009 | 05:50 PM
sdseva's Avatar
loose wire at the sensor is my bet. mine does the same thing until i kinda jam the wires into the sensor. the clip that holds the ends together broke so it kinda comes loose with all of that crazy shake. try that first
Old Oct 20, 2009 | 06:00 PM
yeah I had a look at the sensor and connector felt a bit loose, took it off, checked for corrosion, looked ok to me, and re-connected it. so I will see how it does tommorrow, one more thing, where would a good place to install a direct read temp gauge, (like autometer) because the factory sensor location is a bit of a pain.........
Old Oct 21, 2009 | 07:37 AM
patdaly's Avatar
Cylinder head would be my first location, plenty of plugs to go into.
Old Oct 26, 2009 | 03:18 PM
eng208's Avatar
It is just the plug that the wire goes into. The terminal looses its connection and does this. You can put some dielectric in the plug, then use some electrical tape to help hold the plug tight on the sensor. If you can find a replacement plug, pull the wire out, put a new terminal on it, then reinstall it. This should fix your problem. No need to go putting another sensor in a different location. It is just a loose connection on the sensor plug.
Old Oct 26, 2009 | 05:03 PM
excellent thanks eng208,I will try that tommorrow, will shure save me some valuable time and money.
dieselspeed27
May 18, 2012 09:08 PM
wegotlabs
Mar 22, 2011 01:41 PM
KristinaWitt
Oct 11, 2006 03:26 PM
The Old Man
Aug 12, 2003 07:58 PM
