-   12 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/)
-   -   valve guide seal? update on this? Keep them down? (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/valve-guide-seal-update-keep-them-down-242593/)
j_k_auto May 12, 2009 05:10 AM
I was searching and found that the seal can float up the stem. I am wondering if there is a update for this so this does not happen?
also I came across this..... I wonder if anyone did this?
http://www.turbodieselregister.com/f...oil-seals.html
1320 May 15, 2009 02:38 PM
I couldnt even get the oem style replacements on without damage. I have a wholesale connection, so I just went down to the warehouse and me and a friend started searching. We looked up the replacements, and looked at a few others, then ended up in the warehouse on the ladders, with dial calipers in hand.
I found some that look good. I dont have the part number but I could get it. They fit the guide boss alittle tighter.
They look similar to the red ones pictured in the link, but I have no idea if they are the same major and minor sizes.
j_k_auto May 15, 2009 03:15 PM
Very interesting. I wonder what part you used[coffee]
1320 May 15, 2009 04:55 PM
I made a call, to see what it was I bought.
I bought a viton seal that is, .315 (8mm) x .530
They have 21000 of them and they are about $1.00 each.
I think the oem is around .550 or .570 on the guide.
j_k_auto May 15, 2009 07:12 PM
thanks this should be a needle in the hey stack to find. I can guaranty the parts guys will not be any help on finding this part.[dummy]... only if you had a part number.....
Atleast it is something to start with.... thanks
1320 May 15, 2009 08:34 PM
Thats how they list them ....by sizes. I can get em an stick in an evelope..
j_k_auto May 15, 2009 09:28 PM
I will let you know. I do thank you for the help. Do you have a picture of them?
