trany crazy shifting ????
Old Jul 16, 2007 | 10:02 PM
oldblues's Avatar
Question trany crazy shifting ????
hi
well for some strange reason my trany is shifting in and out of gears at about 35 to 55 mph range ?
it did work fine until sunday evening .
started home about 80 mi trip and noticed it jumping between gears or in and out of lock up , i am not sure ?
it also did not want to up shift to od at times unless i accelerated hard till it hit 2700 rpm then it would go to od and stay there as long as i was crusing 60 + mph .
every time we had to slow for traffic it would dounshift and i would be driven about 50 and engine running 2100 rpm .
normaly it would go to od about 38 mph + light load .
tps is only 3 mounths old and fluid and filter 1 mounth old atf+4
switched relay in fuse box under hood no change ?
bands adjusted and a transgo kit in vb at fluid change .
i am thinking something electrical but it is not showing any codes as i have a odb2 reader and the key on off thing clear also ?
so what do you all think is going on here ?
Old Jul 16, 2007 | 10:11 PM
walkram42's Avatar
Check your battery connections, and give them a thorough cleaning. I had very similar symptoms and I started with the simple things. It seems to have fixed the problem. It's worth a shot, good luck.
Old Jul 16, 2007 | 10:36 PM
oldblues's Avatar
hi
i should have mentioned but i have already cleaned them and used a anti corosion lube they are clean !
thanks for the reply !
what about a speed sensor ? what does it do /control and where is it located ?
Old Jul 17, 2007 | 08:34 AM
kawi600's Avatar
Id check the TPS and the OD temp sensor on the transmission
Igor
Dec 5, 2006 11:08 PM
Atlantic4x4
Sep 8, 2006 09:20 AM
8secondride
13
May 25, 2003 01:49 PM
