Transmission will not shift to 3rd gear when cold
Old Dec 28, 2005 | 12:52 PM
ddt17's Avatar
I have a 1996 dodge 2500 with 150K miles living in St. Louis. The tranny filter was changed and new ATF3 added to the correct level. (1 week ago)The problem still exists. When the outside temperature drops below 45 degrees the tranny will not shift into 3rd gear until warm. ie it has been driven for 3-6 miles in second gear. Once warm the transmission will shift normally. It will when cold also not go into reverse. Any assistance in this is appreciated.
Old Dec 28, 2005 | 09:42 PM
TIMMY22's Avatar
1. set the parking brake on level ground. 2. shift transmission to "N"-wait- 3. check fluid 4. add fluid slowly while at idle in "N" 5. check level.
chevy's you check in "P" dodge in "N"
try this first, you'll be surprised how much it will take.
Old Dec 29, 2005 | 01:16 AM
cumminsdriver635's Avatar
Yes make sure you check the fluid in neutral with the tranny warm. Also; when its cold, they wont shift out of 3rd anyway, but it sounds like you have another problem.
Eric
Old Dec 29, 2005 | 08:53 AM
fuel4me's Avatar
buy a dtt, can't go wrong
Old Dec 29, 2005 | 09:40 AM
Big Deezul's Avatar
No hope for the stocker eh? I would check your fluid and maybe throw in a bottle of lube gaurd
Old Dec 29, 2005 | 07:01 PM
nitrousn's Avatar
Also check the throttle cable that goes to the tranny. Make sure it is free and piviots and returns ok.
hot_runner58
Jul 9, 2016 09:12 AM
jshaw214
Mar 31, 2008 08:56 PM
Tuckerdee
Jan 27, 2008 09:53 PM
CASMOKIN
Competition / Pulls / OffRoad
Dec 30, 2005 01:28 PM
