Transfer case rebuild...advice needed
Old Feb 13, 2008 | 10:02 PM
bkoz's Avatar
I will be disassembly my 241 DHD transfer case if my TC works out. Right now the transfer case clunks in both Hi and Lo. It seems as if the chain is skipping. I have inspected the CAD. It is in good condition.
Does anybody have and advice or tips/tricks to rebuild the transfer case? Is there any good resources on the net?
Old Feb 14, 2008 | 03:29 PM
lifer's Avatar
MY 97 manual cover the t case. If you are going to do a complete rebuild you will need to pull the case and do it on a bench. If you are only doing the chain then you can do it on the truck. You will need to pull the sprocket on the output shaft and then the chain can come right off. If I remember correctly there is a snap ring that holds the sprocket on the output shaft. There was a thread on this here about a month or so ago that listed a parts supplier on the web but I don't remember the name. I think a master kit was about $600 if my memory is right. I think the chain was about $150 or so.
Old Feb 14, 2008 | 05:58 PM
infidel's Avatar
Old Feb 14, 2008 | 11:27 PM
bkoz's Avatar
I am going to pull the case. It is very hard to shift so I want it out of the truck to check that also.
Old Feb 15, 2008 | 06:34 AM
LanceD's Avatar
im doing the same, except just replacing the seals, installing a t-case saver and putting a Goerend transmission in while im at it.
Old Feb 15, 2008 | 09:12 AM
bkoz's Avatar
what's a t-case saver?
Old Feb 15, 2008 | 07:35 PM
LanceD's Avatar
I think its only for the 241DLD. If I remember right it doesn't work or is not needed on the DHD. but its a bolt together collar that replaces a weak snap ring on the tailshaft
Old Feb 16, 2008 | 08:04 AM
n2moto's Avatar
Could your clunk be the connecting collar between the transmission output shaft and the input shaft on the T Case?
Old Feb 16, 2008 | 08:59 AM
bkoz's Avatar
n2moto - are you talking the large shift collar that works with the synchro?
I have the t-case apart right now and that collar shows signs of wear but nothing really significant.
Old Dec 27, 2008 | 08:26 PM
ve7kilohertz's Avatar
Originally Posted by infidel
Hey Bill,
Where did you find this picture? Is there a larger higher res image available? My T case needs a rebuild. I could use a service manual for a 241D but can't find one to save my life.
Cheers
Paul
Old Dec 27, 2008 | 10:46 PM
Checkmate's Avatar
Read the ghost print in the background.
Old Dec 28, 2008 | 09:52 AM
infidel's Avatar
Originally Posted by ve7kilohertz
Hey Bill,
Cheers
Paul
Paul, two good ones to bookmark,
http://www.jameskowalski.com/Dodge/Parts/index.html
and here,
http://search.ebscohost.com/login.as...ile=autorefctr
Username; greatfalls
password; publiclibrary
Both sites require a bit of Adobe experence to reap the entire benefits, stick with it and you'll figure it out.
RichN
0
Feb 27, 2010 04:20 PM
Mike Holmen
ABDTR #5
27
Apr 7, 2009 10:13 AM
Stamey
Jan 18, 2008 08:35 PM
hw101
Apr 13, 2003 08:53 PM
