Trans Cooler Lines & Clamps
Several years ago my trans coolant line sprung a leak and instead of just patching the leak I pulled all the steel lines out and replaced them with high-temp, specialty rubber lines. Trouble is twice now the coolant line coming out of the trans has pulled off it's nipple while I was driving and I've lost all the fluid. It seems the hose clamps I've been using won't hold for long. I double-clamped that line too. I'm not sure whether to try new clamps or put new lines on. Does anyone sell any specialty hose clamps?
Originally Posted by Robert Rausch
(Post 3344820)
Here's what happened. I put the rubber lines on about 6 years ago. A year ago the out-to-cooler line came off and I refilled the trans and put that line back on and added a 2nd hose clamp, and I went around and doubled all the hose clamps. Last month I changed the fluid and snugged up all the hose clamps again... or so I thought. This time the in-from-cooler line came off and I am embarrassed to say I was able to push it right back on--evidently last month when I snugged all the hose clamps I forgot about that one.
I wasn't able to find push-lok fittings locally. I'll keep trying tho. They look like the permanent solution for my problem. |
