Trans Cooler Lines & Clamps - Dodge Diesel - Diesel Truck Resource Forums
Old 03-01-2018, 12:29 PM
Several years ago my trans coolant line sprung a leak and instead of just patching the leak I pulled all the steel lines out and replaced them with high-temp, specialty rubber lines. Trouble is twice now the coolant line coming out of the trans has pulled off it's nipple while I was driving and I've lost all the fluid. It seems the hose clamps I've been using won't hold for long. I double-clamped that line too. I'm not sure whether to try new clamps or put new lines on. Does anyone sell any specialty hose clamps?
Robert Rausch is offline
Old 03-01-2018, 12:55 PM
just replace the hose fittings with "push-loc" fittings. then push your hose on the new fittings. you do not need hose clamps with push-loc fittings. you cannot pull the hose off ! you have to cut the hose to get it off a push-loc fitting. I`ve been using push-loc fittings and hose, on many remote engine oil filters and transmission cooler hose set ups without clamps for 40 years and NEVER had a hose come off. get the fittings from your local hydraulic shop. or Summit or Jeg`s.
jtamulonis is offline
Old 03-01-2018, 05:26 PM
Here's what happened. I put the rubber lines on about 6 years ago. A year ago the out-to-cooler line came off and I refilled the trans and put that line back on and added a 2nd hose clamp, and I went around and doubled all the hose clamps. Last month I changed the fluid and snugged up all the hose clamps again... or so I thought. This time the in-from-cooler line came off and I am embarrassed to say I was able to push it right back on--evidently last month when I snugged all the hose clamps I forgot about that one.
I wasn't able to find push-lok fittings locally. I'll keep trying tho. They look like the permanent solution for my problem.
RoadDiesel
03-06-2011 03:36 PM
Strong05
07-01-2009 01:03 AM
LJTyre
02-06-2007 10:03 AM
EClancy
01-16-2007 09:27 AM
jd knite
04-06-2003 09:28 PM
Quick Reply: Trans Cooler Lines & Clamps
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
