tps to potentiometer
Old Dec 23, 2007 | 03:30 PM
tonystruck's Avatar
How do you do this mod on a 97' 2500.I heard about this mod on first generation. Can this work on a 97' 2500.
Old Dec 23, 2007 | 07:56 PM
mx684's Avatar
i did it to an 02....not sure if 12valves would be the same or not.....come from the sensor signal,sensor ground, and sensor suppy, and go to a relay and potentiometer
Old Dec 24, 2007 | 02:15 PM
OutlawStorm's Avatar
Tonystruck look in my photo gallery the picture is there how to do it on your truck. It works awesome
Old Dec 26, 2007 | 10:19 AM
Dhorn33's Avatar
What does this do?
Old Dec 26, 2007 | 10:45 AM
Originally Posted by Dhorn33
What does this do?
What it does is basic make even a dead TPS work again. Plus it lets you to adjust it to pretty much anything voltage you want it to. I have ran it for almost 2 years on a TPS that Dodge dealer said needed replacing, Its a simple thing to do.
Old Dec 26, 2007 | 11:03 AM
Dhorn33's Avatar
So this would allow me to adjust when the tranny shifts into OD? Mine seems erratic sometimes and it doesn't shift into OD until nearly 50 mph. Did you just mount a switch into the dash or what? From the diagram it looks like you just tapped into one of the wires - is that all it is?
Old Dec 27, 2007 | 10:28 AM
Yes thats all you have to do is tap the one wire. I have my pont under the hood mounted so i can adjust it if i want to,, some have put the pont in the truck and can change it as they drive., On mine i also have the signal wire tapped so i can put the volt meter on it to check or set it easily. Try it, i am sure you will like it
Old Dec 27, 2007 | 09:24 PM
ratsun's Avatar
Outlaw
Probably a dumb question but.......I don't quite understand how a potentiometer works so can you please explain the wiring connections on it for me? It would seem the potentiometer interrupts the ground signal but the pot I have has three posts on it? Also did you unplug the harness from the tps( it dosent look like it but I don't get how you can increase the voltage thru it with it still hooked up)? Thx
Old Dec 27, 2007 | 10:21 PM
steerjock's Avatar
Kinda of off topic but have any of you guys priced replacing the TPS?? I'd like to know what the possible savings could be because i believe my TPS is going bad.
Old Dec 28, 2007 | 09:53 AM
infidel's Avatar
$179 from Napa
Old Dec 28, 2007 | 04:11 PM
SPLnut's Avatar
Does this help with locking up the converter or just OD
Old Dec 28, 2007 | 04:55 PM
TIMMY22's Avatar
Originally Posted by ratsun
Outlaw
An adjustible voltage divider. Kinda like a light switch with an adjustable ****.
Old Dec 28, 2007 | 05:13 PM
~Angry Tractor~'s Avatar
The site below has some tips on cleaning and adjusting the TPS. Looks like it would be worth trying before spending $179.00.
http://dieselgiant.com/dodge_diesel_...nance_tips.htm
Old Dec 28, 2007 | 06:11 PM
infidel's Avatar
The center post is common. The other two do the same thing depending on which way you turn the ****. In other words one post increases resistance while turning while the other post decreases resistance.
Old Dec 28, 2007 | 09:35 PM
ratsun's Avatar
Ok thanks guys.
