TPS help
Old Apr 29, 2006 | 10:06 PM
th_racer's Avatar
TPS help
Hi gang, I think my tps is acting up, my OD shift point went from 40 mph ish to 45 to 50 now to 58 or so. I checked the idle voltage and it is 2.98 with the tps off the mount all the way shut. should I try the hole drilling and cleaning or is there something else sending to much voltage to the tps? Thanks ahead of time Terry.
Old Apr 30, 2006 | 06:06 PM
kandgo's Avatar
https://www.dieseltruckresource.com/...light=pappyman Clean and readjust it, I have also had to take the wires out of the factory looms from the sensor to the pcm and put them in thier own loom. Goodluck,,Rick
Old Apr 30, 2006 | 09:52 PM
snow ram's Avatar
why does it matter if you take the wires out of the big loom or not?
-Josh
Old May 1, 2006 | 10:43 AM
kd460's Avatar
The wires can pick up "stray signals" from the other wires in the same loom. So, putting them in their own loom will reduce the liklihood of this. It helped with mine at Kandgo's reccommendation. KD
whosdunit
May 17, 2014 08:54 AM
timb
Sep 19, 2005 11:08 PM
IH8MYCAT
Feb 7, 2005 04:53 PM
DDysput
May 5, 2004 07:44 AM
ouchman
Mar 31, 2004 02:10 AM
