Tps!!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 21, 2011 | 12:05 AM
Purplezr2's Avatar
Manual Tranny swap?
I know I'm no help, I have a manual.
Old Nov 21, 2011 | 12:08 AM
IanM's Avatar
I've seriously considered it. I want the auto tranny though...
Old Nov 21, 2011 | 05:35 AM
Totallyrad's Avatar
Having not owned a second gen forces me to ask this. On my 1st gen I had problems with it not wanting to go into overdrive and it was at the electrical plug on the driver's side of the trans. Is this trans set up similarly? Could it just be a bad plug or connection?
Old Nov 21, 2011 | 09:53 AM
infidel's Avatar
Voltage at the TPS is low.
A friend went though the same problem recently. Turned out it was the 5 volt supply wire going back the the tranny VSS had chafed insulation and was grounding out.
A wire short problem like this could be anywhere in the truck and cause the same low voltage problem.
I've read of one person who found his short inside of the loom running to the water in fuel sensor.
PITA to find.
Old Nov 21, 2011 | 10:30 AM
IanM's Avatar
Infidel, would a continuity test isolate the problem? Do you have to hand trace the wires until you find the worn out jacketing?
Thanks for all the help guys...I couldn't have done any of this without everyone's input!!
Old Nov 22, 2011 | 08:29 AM
cj360trider's Avatar
A continuity test thru the wire, end to end, wud not. A cont. Test to ground wud tell you if you had a chafed wire to ground. However it wud not tell you where the compromised insulation is at. Another way to test is to run a seperate wire in place of suspected faulty wire.
Old Dec 31, 2011 | 01:06 AM
IanM's Avatar
Alright, I did a continuity test, and the RF filter was grounding the TPS out, but there weren't any shorts.
One of the last items I checked was the linkage. The throttle valve cable was a little off, which lowered second and third gear shifts, and the distance from the back of the bracket to the center of the ball is about 5 1/4".
https://www.dieseltruckresource.com/...rottle+linkage
Infidel posted a FSM diagram showing the distance to be 5" +/- 1mm. How do you adjust the throttle lever?
whosdunit
May 17, 2014 08:54 AM
Paradise Racing
Mar 18, 2003 06:26 PM
hvanflee
Mar 13, 2003 03:11 PM
feets
Jan 1, 2003 11:04 PM
