Too much boost, what to do?
Old Oct 28, 2009 | 06:46 PM
smokeum99ta's Avatar
Awhile ago I put in an boost elbow. The boost would go to 32psi +-. Now, some time later I have no issue getting 50+psi and seems to slow the truck down. I'm pretty sure that much boost is bad on my stock turbo. What should I be looking for to fix the issue?
Old Oct 28, 2009 | 07:20 PM
dieseldemon's Avatar
Check the boost el make sure it is not plugged
Old Oct 28, 2009 | 10:25 PM
Lil Dog's Avatar
Or that the wastegate isn't damaged like a blown diaphragm or hose came off.
Old Oct 29, 2009 | 03:09 PM
Thanks i'll have to check the wastegate. I know the elbow isn't clogged because I took it off and checked.
Old Oct 29, 2009 | 07:26 PM
Brendan's Avatar
On a different note, How do you like driving with full cut delivery valves? I've heard that they can be quite tough to keep clean.
Old Oct 30, 2009 | 05:51 PM
With those fullcut dv's the truck just about smokes nonstop. Not too bad when making boost under 1/2 throttle but any more than 1/2 throttle I can smoke out a town if wanted.
LooseBoltsRob
31
Nov 16, 2007 02:19 PM
MDMIKE
Jan 18, 2005 10:02 PM
NeedMoPower
Jul 12, 2004 10:04 AM
Cumminsdieselboy
Oct 27, 2003 07:36 AM
Wes C
Dec 24, 2002 12:28 AM
