Timing housings new for $130
I've been looking for a housing for my 97 that was killed by the KDP for months on Ebay and car-parts.com. I watched used ones go for over $300 on Ebay. I actually bought 2 used ones that turned out to be the wrong ones. Finally I found several new ones on Ebay being sold by Car City for $130 new. I bought one and just received it today and it is the right one. There are 2 posted right now as I speak. They also have other new Cummins parts as well. Check it out right now, don't lose out on this.
thats a good find.
I wish you would put where to look for them..the search doesn't come up with anything.[dummy]
Originally Posted by TireHauler04
(Post 1348731)
I believe this is what you are looking for. . . |
Thanks Waldersha....sorry about that guys and gals. Type in "cummins gear" on the Ebay search and you will see a few others.
awesome, thanks...so this one DOES fit our 12 valves?And do you guys know if we need a new dowel pin itself to put back in there?Thanks![guitar] I am buying one today if that's the case..{no pun intendid} [laugh]
Can Someone tell me if you need a new dowel PIN itself to stick back in this new cover?I need to know before friday if anyone knows...thanks much![guitar]
No need for a new dowel pin if the old one is still there.
Which brings up the question why replace the case unless the pin came out and damaged the old one? If the pin did come out you definitely need a new one. |
yep pin came out..need new pin I guess
Here's the pin part # through Dodge...04429257. I have all the gaskets, seals, etc., and finally the housing. I just need to get that rebuild kit for my vacuum pump yet. It's a lot easier to get to with the housing off. Don't forget the chunk of metal to hold the new pin in. Hopefully I'll be starting to put mine back together in the next few weeks. Check out the guy that I got the housing from, I see he has some of the gaskets. Cummins is cheaper than Dodge on most of the parts. I wish I would have thought about that before I bought all these Dodge parts. Ah well, that's how we learn.
