Timing Case Gasket and KDP
Old Apr 13, 2006 | 11:48 PM
Dr. Evil's Avatar
Alright guys, for those of you that have fixed the KDP, did you go with a new timing case gasket, re-use the gasket or just use some RTV to seal it??
Thx.
Old Apr 14, 2006 | 01:32 AM
fordsux8269's Avatar
I re use the gasket and RTV on each side of the gasket. I used ultra grey rtv
Old Apr 14, 2006 | 03:03 AM
TireHauler04's Avatar
Wink kdp
I bought another gasket from Cummins {$30 roughly} and used the high temp grey silicone to re-seal it, it's cheap insurance not to leak, make sure your bolts are tight too..that helps
Old Apr 14, 2006 | 08:48 AM
TxDiesel007's Avatar
Thx.
I used both,
The RTV sealant and the ultra grey, problem was with that KDP kit, that they dont give you enough of either or, so i went and bought some more ultra grey at the autoparts store three blocks from home...
My original gasket was in pretty good shape, so i reused it... Also the tight bolts help too...
Rick
Old Apr 14, 2006 | 10:09 AM
ratsun's Avatar
Goin in for the kill Dr.?
I used a set that I got from PDR that had a new gasket/tab/crankseal with installer.
Very cheap. I also used the RTV for a added measure and to hold the gasket in place while putting it back together.
Old Apr 14, 2006 | 10:13 AM
Dr. Evil's Avatar
I priced the kit at BD Diesel....$136...I dont mean to sound cheap but Id like to spend my hard earned $ elsewhere.
Old Apr 14, 2006 | 10:26 AM
I bought the TST kit
for 57 bucks (american) it comes with the tab, seal, seal installer, and some sealant and anti seize.. I reccomend it to anyone and everyone.. INfact here is my writeup on it..
Dr Evil, check out the link below, for 50 bucks u cannot go wrong, hope it helps u....
https://www.dieseltruckresource.com/...repair+TST+kit
Rick
Old Apr 14, 2006 | 11:14 AM
Baja's Avatar
The TST kit works great, I just used sealent. So far, no leaks, everything holding well. Just make sure all surfaces are clean.
Old Apr 14, 2006 | 11:47 AM
ratsun's Avatar
DR.
BD here in Abbotsford are the same clowns that quoted me $1100 for the same Comp every one else in town was selling for $750-800
Contact PDR on Mon/Tues im sure it was less than $50cdn for the stuff when I did mine. If you want let me know and I will find out early next week for you as I'm going there anyway
Old Apr 14, 2006 | 11:51 AM
torquefan's Avatar
I use a new gasket and seal. Then I know I won't have to go back in there for a long time.
Dr.- what year's your truck? If I remember, they deleted the gasket on the 24 valves, and went to an RTV seal.
Old Apr 14, 2006 | 11:52 AM
turbo thom's Avatar
Dr Evil, you can. Like is a diesel repair shop to the tune of about $2400.00.
But when you go in, replace the crank seal, gasket, with no sealant. It's not necessary and just make a mess.
Old Apr 14, 2006 | 07:24 PM
infidel's Avatar
I toss the gasket even if it's in good shape and use just RTV.
Old Apr 15, 2006 | 12:52 AM
Iron City's Avatar
I bought the gasket from Cummins, not too pricey, seems to be working great. I used RTV on the cover side of the seal.
Old Apr 15, 2006 | 06:39 AM
JKM's Avatar
JKM
He has 2 of them , an 01 , and a 98 12v.
Old Apr 15, 2006 | 09:16 AM
DRD's Avatar
DRD
I just bought the seal from Cummins and made the tab. Silicone for the cover, my 24 valve did not have a gasket.
