These High Dollar TPS's
Old Apr 14, 2004 | 02:36 PM
pappyman's Avatar
Maybe if the dealership sold parts for these I bet that little contact strip would cost $49.99 plus shipping and tax
Old Apr 14, 2004 | 04:28 PM
CruisingRam's Avatar
Okay- what is a TPS and what does it do? What years are a problem for this?
Old Apr 14, 2004 | 04:40 PM
pappyman's Avatar
Every thing is here just click on TPS
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Old Apr 18, 2004 | 10:41 AM
Yamadad's Avatar
Thanks Pap, I think mine is going to. With this info, I might as well do the clean method. If it doesn't work, then all I'm out is a little time. Cool stuff!
Old Apr 18, 2004 | 06:26 PM
linetrash75's Avatar
hey guys i think im having problems with the tps on my 99durango 5.9 gas. intermeditaly run you depress the pedal it will rev and not come back down to idle ,also the trans seeme to hunt some dropps out of O/D to soon. mine looks a little different on the outside but i'm sure it pretty much the same on the inside. I just want a second or third opion before i open it up, what do you guy s think? another question is there a forum for the gas powered dodge riggs?
jed
Old Apr 18, 2004 | 07:19 PM
Crimedog's Avatar
My mom had that on her dakota (99, 318). It only happened one night coming home, I asked around and I guess there is no external sensor like on our trucks, it needs to be reflashed. On hers it just went away.
Old Apr 28, 2004 | 04:57 PM
mr T's Avatar
guys...where exactly is the TPS?? just so i dont spend hours following cables around hoping i got the right thing....im startign to gear hunt every other day or so now..how big is it exactly....or what marking does it have on it so i know i got it
Old Apr 28, 2004 | 05:31 PM
infidel's Avatar
Old Apr 28, 2004 | 05:59 PM
mr T's Avatar
ur the man infidel
Old Apr 28, 2004 | 10:13 PM
mr T's Avatar
ok i just finished putting it back together...havent sealed things yet...in that hole.....what is that lil wire hanging out??? AND when i put it together how does that play in in the fitting process?....the censor inside was filled with crap...was ridiculous..looks brand new...now i just hope i got the two pieces fitted together properly....need input and feedback on the orientation of the 2 pieces and that lil wire in the hole plz guys
Old Feb 9, 2005 | 01:58 PM
capt.Ron's Avatar
I think I can... I think...
Originally posted by pappyman
After looking these over I can see no-way for contact cleaner to get inside these TPS's because of the seal around the shaft so I drilled a 1/16 th hole thru the back side .283 from the bottom lip to be able shoot cleaner into the insides then resealed the hole with silicone
Is a 1/16 hole big enough? It's not as big as the spray tube on my can of contact cleaner.
Will the cleaner, dirt and debris be able to drain from such a hole?
Old May 18, 2005 | 08:55 PM
BoostdCTD's Avatar
Pictures are now missing.
Old May 19, 2005 | 05:53 AM
pappyman's Avatar
I think the photos are gone because they where not in my gallery when the forum was changed
I'll look around to see if I still have the photos on a floppy disk and if I do I'll put them in my gallery
Old May 19, 2005 | 08:28 AM
BoostdCTD's Avatar
Ok, cool.
Old Oct 2, 2005 | 01:04 PM
8secondride's Avatar
My truck's doin' the same: erratic shifting with/without load. Mashin' on the gas is ok, just erratic shifting when I'm cruizin' on the highway upshifting and downshifting. I'm gonna drill into the TPS and flush it out. Any recommendations before ? I'm goin' on your info.
