TC Lock Up Switch...Plse explain.
Old Feb 3, 2008 | 07:34 PM
canuck ram's Avatar
I have done several searches and found lots of info and the install seems very easy, but could someone plse explain the advantages?...If the tranny is working properly the TC is going to lock up anyways. I may be missing something, but other than keeping it locked to slow down with the engine I don't understand why you would want to force it to stay locked. Does it have any effect on acceleration or lo end pwr? What do those of you who have it installed think about how it works? Is it worth doing for towing applications?
Thanks
Old Feb 3, 2008 | 08:11 PM
ratsun's Avatar
Hey fellow Canuck, where's home?
The lock up switch works great when towing or racing.
In stock trim your converter unlocks when you lift off the accelerator and your rpm drops below a set (14-1600rpm I think?) rpm and you loose all engine braking, with the switch you can force lock-up to help slow the truck.
Also in stock trim your converter unlocks anytime you go full throttle so if your racing it makes a huge difference (.5 second in the 1/4) to keep it locked
There are things you must consider however with the switch
a) at times of low rpm your line pressures are low and forcing lock-up without enough pressure will cause the clutch to slip.
b) locked shifts are hard on parts and can cause shaft (generally output shaft) breakage in trucks with added hp.
Old Feb 3, 2008 | 08:16 PM
j-fox's Avatar
The stock converter is so loose in fluid coupling a few like to force lock-up to make it like a manual trans.
The issue comes later when they find it 'cool' to let it shift while locked!!!
This is not how the trans is designed to work and breaks things like the input shaft.
It is better to get a tighter converter and be happy.
i had a lock-up switch when mine was stock/lower power, but removed the switch when I found how nice a tight converter is.
Old Feb 4, 2008 | 06:21 AM
canuck ram's Avatar
Thanks!
Thanks for the explanation fellas! The more I ponder this it seems there is no way around it...I should just bite the bullet and replace the TC and VB. Everyone raves about what a difference it will be but there is no one in the area (Petawawa, Ontario...kind of a 1 horse town) that has done this so that I can actually get a first hand experience of the changes before spending 3k+.
Old Feb 4, 2008 | 06:19 PM
one54ton's Avatar
its a very easy install (great diagram on tst website) just dont abuse it
snowmanx
Jul 17, 2009 12:56 PM
SPLnut
Dec 31, 2007 11:27 AM
DirtEater
19
Aug 31, 2005 08:35 AM
mr T
21
Jun 1, 2005 08:48 AM
damon_achey
Jun 7, 2004 03:33 PM
