takes a llittle longer to start....
Old Nov 7, 2007 | 01:39 PM
wcbcruzer's Avatar
Dr. Evil - Thanks for posting the links. I might go with some 2/0 cable from the first website you posted. Did you see custom cables being offered for cheaper than that?
Old Nov 7, 2007 | 01:49 PM
Dr. Evil's Avatar
You would probably have to talk to them directly.
Before you decide to do this have a look at your trucks cables because you will have to get some smaller lugs and some smaller guage cable (for the drivers side) to go to the PDC etc. I had a lot of the stuff on hand so I cant really remember what I used.
Old Nov 7, 2007 | 09:09 PM
West Coast's Avatar
Thanks for the response Dr. Evil. My ground cables are in good shape. Just the ground cable end is bad. I just need to get two new ground connectors.
Old Nov 7, 2007 | 09:19 PM
West Coast's Avatar
What are the stock cable sizes? Thanks......
Old Nov 8, 2007 | 09:36 AM
Dr. Evil's Avatar
Sorry got a little carried away....shouldnt be too hard to change the ground clamps.
As for wire guage, if no one answers Ill try to find my old cables and let you know.
Old Nov 8, 2007 | 09:04 PM
West Coast's Avatar
Well I replaced both ground battery clamps today with NAPA cable ends. Less than a 10 minute fix and truck started right up after install. I am thinking the bad grounds where causing my battery to not get a full charge thus causing the no start issue.
Thanks for the suggestions and help guys.....
Dave
Old Nov 9, 2007 | 07:57 PM
West Coast's Avatar
I received my larger starter contacts today in the mail. Truck still having issues starting. I am going to check the starter in the morning to make sure it is good. Then I will install the new starter contacts. Are the starter contacts in the solenoid? Is the starter/solenoid one unit or seperate? Thanks..
Old Nov 9, 2007 | 10:14 PM
Dr. Evil's Avatar
You will find this very handy - written by our very own Cumminsdriver635:
http://kydtr.com/iboard/index.php?showtopic=3755
Old Nov 9, 2007 | 10:34 PM
West Coast's Avatar
Thanks Dr. That helps a lot. I will report back tomorrow after I change out the contacts...
Dave
Old Nov 9, 2007 | 10:40 PM
Dr. Evil's Avatar
Good Luck Dave hope you get it figured out....then you can come up and help me with my truck issues. (bring ca$h)
Old Nov 9, 2007 | 10:42 PM
Dr. Evil's Avatar
Hey, I have a question....are you running caps on yoru wheels? Do you have a close up pic of your wheels?
Old Nov 10, 2007 | 01:22 AM
West Coast's Avatar
Yo Dr installed the new contacts tonight and......... NO DEAL....
Still has intermittent start issues. And when it does not start I can hear a slight click. Must be the starter..... I am going to try NAPA tomorrow. Can they bench test a starter to ensure it is bad before I lay down some cash for a new one??
Old Nov 10, 2007 | 01:24 AM
Dr. Evil's Avatar
Do you have caps? I cant see it the wheel very well...
Looks great BTW...
Old Nov 10, 2007 | 01:36 AM
West Coast's Avatar
Yeah I have caps on.....
Here are my exact rims..... http://www.procomptires.com/pxa7089.html
I just ordered this: http://store.summitracing.com/partde...0&autoview=sku I will pick up the starter in Reno tomorrow.
I am assuming with the powermaster starter I do not have to install the larger contacts?
And Infidel what idle speed should I be running in my 12v? When the starter does work it does start much better if I give it a little pedal on start.
Old Nov 10, 2007 | 07:51 AM
Dr. Evil's Avatar
Great Thx...just what I was looking for
And thats pretty good price on the starter. Not sure about the HD contacts on the new starter, you could take a peak at them.
You should be idleing at a hair under 800 rpm. But, I read that the tsock tach isnt all that accurate when adjusting idle.
