Starwheel Question ??
Old Nov 5, 2008 | 03:14 PM
murphy41's Avatar
What exactly does the starwheel do for performance ? And which will make more power, sliding the afc forward or turning the starwheel forward ? or both ?
Old Nov 5, 2008 | 04:07 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Adjust both your star wheel and AFC.Move the AFC full forward toward the front of the truck and turn your star wheel also toward the front.The star screw adjusts the tension on the spring.Less tension and the governor will push the foot easier at lower boost.
Old Nov 5, 2008 | 04:59 PM
97 D-Tec's Avatar
the star wheel only adjusts fuel inrelation to boost.. adjusting it too far will cause the injectors to dump too much fuel before the turbo can realy light which can hurt performance
Old Nov 5, 2008 | 05:07 PM
murphy41's Avatar
Ok thanks cause i took the afc arm out and it runs great if i drive it right, but smokes a little too much ? So if i put the arm back in and adjust the starwheel? if im running a bigger turbo where should i turn it too ?
Dhorn33
Nov 26, 2007 12:31 PM
513yj
May 20, 2007 04:03 PM
CTD2001
Mar 12, 2006 08:34 PM
luie
Aug 20, 2003 10:36 AM
cummingetit
16
May 17, 2003 03:38 PM
