starter problem?
Old Feb 2, 2009 | 12:04 PM
94ram's Avatar
starter problem?
hey guys, im having some problems with my starter. for about two months i went through four 40 amp starter fuses(i think its the ignition fuse in the fuse box). they would just blow out when i would turn the key. i would have to get underneath with a screwdriver to the starter in order to get it started.
so, i went a head and put in a 50 amp fuse. it went for about three weeks without a problem.
yesterday i went to hollister hills(off-road park nearby) and at the end of the day, the symptoms came back except the fuse wasnt blown. when i went to start it, it would just "click" and it wouldnt start until i turned the key again.
so i was wondering what the problem might be, do you guys have an idea?
thanks, sal
Old Feb 2, 2009 | 12:09 PM
Lil Dog's Avatar
Have you had the starter apart? Most times the starter contacts are the problem and you can replace them with upgraded parts from Foster Truck. The blown fuse on the start sequence may be due to the contacts or possible short in the brown wire to the starter solenoid.
You could try to swap relays in the PDC.
Old Feb 2, 2009 | 12:12 PM
infidel's Avatar
Change the starter contacts ASAP before they finally stick, burn out your $200 shutdown solenoid, melt wires and possibly start a fire.
Old Feb 2, 2009 | 12:51 PM
John Faughn's Avatar
Putting higher rated fuses in , is asking for trouble , no matter what your doing , trucks & cars , or house hold .
When the engine start knocking , just turn up the stereo .
Old Feb 2, 2009 | 04:08 PM
gmctd's Avatar
Yep - rebuild starter now or things will get worse - much worse - and, put the oem-rated fuses back in the box when finished with the starter
Old Feb 2, 2009 | 07:46 PM
94ram's Avatar
ok thanks guys. ill see if i can those this week.
i rather spend the money now instead of later after ive had an electrical fire
Red3quarter
Sep 9, 2012 05:25 PM
FMB
Nov 14, 2010 09:09 PM
12valvesmoke
Jun 12, 2009 09:46 AM
buckman361
Nov 13, 2008 09:54 AM
Paradise Racing
Jan 18, 2005 09:08 AM
